It's a matter of being aware of the risks *LINK*
Craig Daymon
Many of the members of the Bucks County AAW group that I belonged to when I was in PA would state that if you weren't sensitive to dalbergia, you will be. That being said, many of those same members continue to turn and use rosewood by taking precautions. Many also keep an epi pen in the shop.
The fact of the matter is there are inherent risks with working with wood. The metal dust from sharpening is quite hazardous, but I'll bet there are few turners that bother to wear a dust mask when sharpening. Acetone, Mineral Spirits, Ammonia? Heavy metals in finishes. Working with aluminum dust to fill voids.
Like I already stated, I have found I have a sensitivity to Beech. It didn't stop me from finishing the turning. You also can't grasp just how sensitive I am to poison ivy, therefore that Australian lacewood is something I have to be very careful of. Inhalation of some of that dust (very possible even with a dust mask and dust collection) could pose a serious problem.
This weekend I will be using a propane torch to burn the inside of a hollowform. Precautions must be taken and it is not something I'll be doing in the shop.
I'm sure you're also aware that there are sharp edges on the tools you use. As illogical as it sounds, your sharp tools are safer for turning than dull ones, but that doesn't mean that your likely to never get a cut. (I think someone here mentioned getting a skew in the foot about a month back.)
Let's not forget spalted wood of any variety. Those very safe maples are frequently spalted and spalting is caused by a fungus and even when the wood is dry, the spores are simply dormant. NOT dead. Breathe in that dust and you are opening yourself up to some very serious risks. Remember that mushrooms and toadstools are fungi and many are toxic.
I've put a link to the Wood Database below. It pays to try and learn about the woods you are using, especially the risks, but also movement, workability, finishing, color change with age and light, and gluability. (Not sure about the spelling of that last word.) You might be surprised how many woods have some level of sensitivity associated with them.
I'm not convinced the database is the holy grail of wood info, but it is a great first step.
Sorry to drone on, but it's just that there are a lot of risks associated with this hobby, many of which are largely ignored. There are also people that have worked with any of these risks without issue. That being said, it does not mean we should ignore the risks. Many of those risks are associated with long term impacts and not ones so immediate as those associated with rosewoods.
-Craig
Wood Database - Check risks before turning
