REAL MILK PAINT
Stopping the Wobbles...
Re: Stopping the Wobbles...
I like his technique better than mine. I use a dowel and move it in slowly across the tool rest against the end of the wood until it runs true. I've seen it done very accurately on a metal lathe using a free rotating bearing in the tool rest to push against the work. I thought about making one of those.
I have used my method to true up bowls that have gotten knocked out of center by a catch. Loosen the chuck very slightly and turn the lathe on at slow speed. Then push the dowel in against the rim until it runs true. Tighten chuck.
If you could put a screw adjustment on one wheel of a steady rest you could use that to true up bowls or hollow vessels that get knocked out of true. Not that any of us have done that you know, but just in case our students do. :)
Steven Antonucci
great tip
Ya-but
what's a "tommy bar?" Them Aussies were called Tommies during WWII [no idea why] so is this some special creeky Australian thing?
Only time I gettin' the wobblies is when me 'n tha mates a'bin hoistin' a few, but aw'll not be runin' the lathe when that happens anyways, eh?
Steven Antonucci
Two tommie bars on older chucks...any rod is fine.
Re: any rod is fine.
A-Rod? Rowdy RODney Piper? Rod Steiger? Johnny Rod?
[psst - steve, that was a joke. I know about those chucks; had one. :D ]
Dick Hines
Dick Hines
Nothing is really new. My grand father showed me how to do it when I was a kid. My way is a little different though. I set the tool rest just short to the piece I want to true up and then use the back of a gouge to lift the piece while it's turning. I did a demo last Nov and the finial I was turning was not running true. I did this and a club member who has been a turning pro for years said, " never saw that before"
It will work with bowls and hollow forms that have been removed from a chuck and the replaced.
Charlie Anderson
Dennis RODman!
Me Too
If I have to take a chuck-mounted jar off the lathe before it's done, I've used the same method to get it running true again. I usually use a piece of wood as the spacer.
That
far out, it will never run true. ;)
Steven Antonucci
plus the piercings will mar your surface.
Used it last night-worked great!
