OT ? : Chuck lubing tip
Jim Breeden
When I received my last Nova2 Chuck and, set about disassembling and cleaning all the sticky shipping crud (grease ? :b ) out of it, using lacquer thinner. But, what to do about a spot of lube to make it operate better. I know not to use any dust attracting material to gum up the works - hey! - I have some Permatex Anti-Seize, part #133A! All it takes is a q-tip to apply a spot to all the moving parts, i.e., scroll, gears, and jaw sliders. Not to much, as "a l'il dab'l do ya". Also, put a dab on the jaw screw threads to prevent the screws from "locking" in the sliders. I usually disassemble my chucks every six months or so for cleaning, and have as yet to find any dust, dirt, etc, attracted to the anti-seize.
Re: OT ? : Chuck lubing tip
Bernie Weishapl
Jim that is good to know. I have some of that anti seize but was afraid to use it or any grease for fear it would clog up with dust. I just cleaned mine yesterday. I ran them thru my clock ultrasonic and it does a great job on them but I lubed them with graphite. I also have some spray lube that dries into a dry lube. It does work pretty well but can't find it anymore and the can is about empty. I guess next time I will give the anti seize a try.
Dale Miner
For several years now, I have been using a can of dry film lubricant that contains moly disulfide. Comes in a sray can; easy to apply, dries fast, makes the moving parts look charcoal dust colored. It does not gather dust from sanding or turning.
John Veerkamp
Dry lube is used widely in electrical motors and in farm equipment. I get mine at a farm supply store. It is also sold as lube for garage door openers. Found with the door openers not the lubricants in box stores.
Devon Palmer
I've had good luck with Teflon dry lube. http://www.amazon.com/DuPont-Non-Stick-Dry-Film-Lubricant-Aerosol/dp/B003UTX0R8/ref=pd_sim_hi_5
Harry Robinette
Harry Robinette
I've been using PG2000 for my chucks,also the ways on my lathes and anything else that get's in my way.
Another possibility
I used to use White Lightning (bike chain lubricant, not moonshine) on tablesaw worm gears and other dust-sensitive parts (gibs, screw threads, etc.). Never tried it on a chuck, but I'll bet it would work great. I think it is a solvent-borne wax emulsion that is dust repellent when dry.
Re: Another possibility
Mark ravensdale
I use a lube on my workshop door locks (padlocks ???) you spay it on as a liquid, but then after abt 1 hour it turns to a wax like lube, bet that would work ok!
Personally I dismantle and clean my chucks every 12-18 months and so just use normal grease on them (but not too much of course!) never had a problem with them fouling up or getting sticky in 9 years of constant use ( every day 2-5 hours)
I too have tried that anti stick lube before (copper grease???), and as long as you don't get heavy handed with it it works ok, I use it on the screws that hold the chuck jaws on, whenever I buy a set of oneway chuck jaws the screws that come with them always seem to have it on them so it must be ok I think (I hope!!!)
Jim Breeden
Thanks for all the lube tips everyone. I was trying to figure out what to use that I had on hand, and the anti-seize was it. I used to rebuild engines in another lifetime, and that's what we used to keep the rocker arms from galling and the cam lobes from scorching on initial startup, so I figured what the heck, this see what happens. Of course we used more that a lil' dab, more like a glob.
