Lee Valley Tools Wooden Vase article
North of the Border
I am going to try this vase as it looks simple to turn. http://www.leevalley.com/en/newsletters/Woodworking/7/4/article1.htm
Does it matter if the inside is not dyed? Thanx.
Re: Lee Valley Tools Wooden Vase article
Brad Vietje
Brad Vietje
Hey North of the Border (which border?),
Looks like a nice little project.
If your bored hole ends up just a little off center, the side walls couls be uneven, so you could drill first, and then finish turn the outside.
Here's what I would do differently:
1. I would start between centers, and turn a tenon (technically a "pin", since tenons are not round ;), but everyone calls 'em that), sized and shaped to fit your specific chuck jaws. Most scroll chucks have a better grip when contracting onto a cylinder or properly shaped dovetail than onto square stock -- especially over-sized square stock. This will also help avoid safety issues with those spinning jaws and jaw slides sticking out beyond the chuck body.
2. I'd turn the square blank to round while between centers, and true it up once transferred to the chuck. I would leave the entire diameter a bit large at the moment.
3. Now drill the hole out, and clean it up, sizing it as needed for your glass insert.
4. Bring up the tail center again and re-center it on the actual hole before finish turning the outer surface. This assures an even wall thickness. You may need to turn a little plug from scrap wood to fit into the drilled opening if you don't have a large enough tail center cone.
5. Drill holes or make cut-outs.
6. Now finish turn the outside between centers, sand, polish, and color as desired. This can clean up the edges of any drilled holes that were not cleanly drilled.
7. Part off with slight concavity to the bottom.
8. Optional: reverse turn using chuck (expanding into opening) or jam chuck turned and sized for a snug fit, in order to slightly hollow and sand the base.
Have fun -- I hope you show us what you make.
Safe spinning,
Brad Vietje
Newbury, VT
North of the Border
Thanks for your response and suggestion.
