The this started out as an idea for a stylized minimalist multiple axes piece - a Masai Herdsman (see earlier The Pencil Is Mightier Than The Spear thread). Intending to do just a little carving to add a little detail, this is becoming more of a carving than a turning (actually the wood removal is being done with small dental ball burs). Faces - I can do them - albeit at a snails pace. Folds in a robe - well that's another matter all together. Have to work on that.
When I get this version of the Masai Herdsman done and colored, I'm going to go back to my original idea - everything turned - on multiple axes - minimalist form, color used to distinguish hair from skin from robe.
Comments, questions and constructive criticism welcomed. The line down the forehead is a filled crack in the wood.
(got to do something about the Prince Valiant hairdo. Maybe carved braids will help)
don't get stuck on turning vs carving, follow the idea.
I had that same (ok, similar) conversation with Ellsworth about glass artist vs woodturning, and it really is about the result, not the tools.
The result shouldn't be constrained by the tool or the thought of what the community will think, let the execution speak for itself. If you are afraid (poor choice of words) of what others will think, you are going down the wrong path. If you want the results to represent your vision, who cares what tools got you there.
With that said, if you are looking to do this all on the lathe, or singular (or whatever) tool, pursue it and learn from the issues with each.
I totally agree that it's the results, not the means of arriving at the results - the message not the medium. But the medium can dictate, or influence, how the message is created - in this case wood, a lathe and a turning tool or two. This carved/ sculpted version of Masai Herdsman is the result of my not following my original instinct - to present a minimum of visual information to evoke the memories and assumptions in the viewers' mind that they associate with the Masai - and Africa.
The more detailed carved Masai is very much a Western / Euro approach to getting an idea acrossed - THIS is what I WANT you to see (and maybe feel). The original idea, all turned, no carving, was more Eastern/ Oriental - Here is a minimal amount of information - YOU fill in the rest. Provoke vs Evoke - Push vs Pull
I've turned most of what I originally intended. Still have some thinning of the profile to emphasize the tall slenderness of the Masai. Went to an art supply store today and got the Golden's Fluid Acrylics colors I need but didn't already have - 2 reds, burnt sienna, raw umber, cad yellow, orange and ochre as well as charcoal black and pthalo blue. Already had the Doe's Hoof brushes and other colors, purchased after the Jaques Vessery demo at the San Jose 2012 AAW symposisum. Have done some color tests on a turned piece of pear wood I had handy and found the color mixes I'll be using.
A friend suggested using a pyro pen to burn in the braided hair, rather than carving them with dental burs. Hadn't thought of that option. Will do some tests using both methods and see how they paint.
Soliciting suggestions, comments and constructive criticism is not always to get external validation. In this case it's to get other perspectives and possibilities. Learning from others is one of the many things that makes Wood Central such a valuable resource.
