Cheap CA glue
Ryu Ueda
I have been purchasing CA glue from Wooden Wonders last few years. However this dealer discontinued selling CA glue. Do you know any cheap CA glue dealer like Wooden Wonders?
Cheap CA glue
Ryu Ueda
Re: Cheap CA glue
Dale Miner
I recently purchased a pint of CA at what I felt was reasonable cost from Star bond.
starbond.com/
Star bond also has some dispensing items that are worth looking into.
Re: Cheap CA glue
Barry L Elder
Exotic Blanks bought his stock and is selling the product now.
Re: Cheap CA glue
Jim Breeden
It is my understanding that CA has a shelf life of 6 months, +/-. It is best to keep it in the freezer to extend the life - it will not freeze. So, if CA is imported, how long did it spend on a ship in a heated invorinment from whever it was made? The only CA I use is from Craft Supplies (www.woosturnerscatalog.com) which is made here in the USA, so they say. By this I know it hasn't spent a month + on a ship somewhere, then sitting on a shelf for who knows how long. Customer service
at Craft Supplies tells me the turnover is short, so we should not have any problems.
Re: Cheap CA glue
Rob Wallace
CPH Starbond has been a long-time supporter of the AAW and usually has a booth at our annual AAW Symposium. He sells in "small bottle" quantities, or in larger bottles, making the purchase of larger amounts quite economical. I have bought CA glue from him for years, and I keep mine refrigerated and dessicated over silica gel in a large, wide-mouth glass jar - it lasts for at least 2-3 years under these conditions. In my experience, this CA glue is of excellent quality. (By 'cheap', I hope you mean inexpensive, and not low quality.) I do not know if he exports to Japan or other places, but you certainly could inquire. The company is located in Los Angeles. See: http://www.starbond.com/
Rob
Re: Cheap CA glue
steve worcester
CA has about a 12 month shelf life without cooling, but humidity is it's enemy. So a fridge may or may not help. Like many things, expiration is expiration
Re: Cheap CA glue
Ryu Ueda
Thank you very much for everyone. I have already sent e-mail to Starbond and asked
whether they can ship out their products to Japan or not. After receiving the replay I will decide ether Starbond or Exotic Blanks. I am satisfied the quality of Wooden Wonders products. I am sorry using wrong word.
warning about any CA glue
Mike Foster
I am just back from the Totally Turning symposium. It was a great show with a wonderful cast of presenters including Binh Pho, Steve Sinner and Mike Mahoney. Steve Sinner related something I have heard from other sources just recently regarding CA glue. His source was conservators from the Smithsonian. CA glue reacts with water and continues to react with water if exposed. It will keep on reacting to the point it actually turns to dust. I have now heard from multiple sources the same story. I was unaware of this issue with CA, however I did know that you could use a spritz of water as an accelerator. The conservator could not put a time line on when CA turns to dust, but factors such as the porosity of the finish, the climate it is exposed to etc.. are all variables. Water from the atmosphere is enough to keep the reaction going, and eventually it will get to the CA glue where we tend to use it. So if you don't want your piece to have repairs turning to dust where you have voids, cracks ..... use epoxy. I'm not throwing my CA away, but will limit the places I use it to temporary fixes, not where I want it to last.
Re: warning about any CA glue
Mike Stafford
Several years ago, actually more that several, my son participated in a problem solving competition called Odyssey of the Mind. His team chose to try and solve the problem where they were allowed to use a certain weight of balsa wood which could not exceed 1/8" square to build a structure to hold as much weight as possible.
My son was the builder and he always carried back up structures to the competitions in case his primary structure did not make weight. His primary structure always made weight so at the end of the year we had a couple of structures left over.
We did nothing with them but display them on book shelves in the den and one day more than a year later we decided to test them. We had a testing stand that allowed us to pile olympic barbell plates on the structures which we did at the college where my wife teaches in the weight room.
Well, before we had 200 pounds on the structures they shattered in a cloud of dust with all the failures being at the glue joints. Some of the wooden pieces broke but primarily the joints failed. The glue was noted on both surfaces at the glue joint but it had crystallized. So as Mike said it is not for long term use.
By the way we always transported and stored the structures for competition in plastic containers with tight fitting lids and included a desiccant canister to keep the structure from absorbing moisture.
My son's team took 6th place in the Odyssey of the Mind world finals at Iowa State in 1994 by holding up 1195 pounds with a 18 gram structure. The team that won held 1560 pounds and the structure did not break. They just ran out of safety pipe.
Bob Moffett
That's good information and points to keep in mind when using CA.
Don Orr
I'm with Mike here. I was in the same demo room with Steve Sinner and I believe his information to be accurate as I have heard it before. I avoid CA glue mostly because I don't like using it in general. I wonder what is going to happen to all those pens people make and finish with CA glue.
I can tell you for a fact is won't hold up to wood movement issues. I started making my hand mirrors and used CA glue to fasten the handles to the body. Every one of them fell out in just a few months. CA doesn't move with the wood.
I kind of reminds me old hide glue. It is very brittle and powdery after 30 to 50 years. I've done a lot of furniture repairs and see this often. I'm kind of guessing that CA is similar in how it degrades. I still use it to repair small tearouts and cracks. I've used it for years on my Christmas ornaments and adding some details to my mirrors. Usually these are tenon joints with no weight or handling involved but now you have me worried about even that joint breaking later on.
Mike Stafford
Nothing beats plain old yellow alihphatic resin glue for wood to wood joints.
I don't use CA glue for pen tubes. I use polyurethane which is gap filling and tenacious. A little messy sometimes to clean up but always successful.
Quicker is not always better.
Another Misconception
Don Orr
Sorry Mike but PU glue is not a true gap filling material. Sure it expands into gaps, but it only fills them with brittle, gas filled foam-just like what oozes out of the joint. Same as the expanding foam insulation in a can. The only truly gap-filling adhesive is epoxy and even that has limits to what size gap it can fill and retain its structural strength. PU glue is a good adhesive used in the right application but is not as strong as many other common adhesives. Fine Woodworking magazine did a test a few years ago that proved it.
Ric Taylor
Not to start an argument or to be a strong proponent either way, but to simply state that my results have been very different.
I have been using CA glue for many applications since the early 1970s. I have a number of pieces that I made (in another hobby) using quite a bit of CA glue in 1975, both in joints and as surfaces. None of the CA glue joints or surfaces show any evidence of degrading in any way. They are just as good as the day they were made 38 years ago.
Ric
