Help identifying old lathe
Jack Guzman from Maine
I'm trying to find out who made this lathe. The bed is 4' long and appears to be made from aluminum or some other light alloy.---Jack
motor in pic not original
Re: Help identifying old lathe
Greg Haugen
Jack,
I've tried looking around for a bit this morning online but no exact matches. It's similar to the old Dunlop/Craftsman lathes but the elements of it look much more like an old metal spinning lathe.
Not much help, I know.
Greg
Logo
I'm thinking it probably is a craftsman or a brand they sold in the 30s-50s. There is a faded sticker on the front of the bed that you can just barely make out in the picture. It is round with red and blue in it. Also on the left side of the bed is traces of another sticker,rectangular in orange with black lettering.---Jack
Re: Help identifying old lathe *LINK*
Galen Vetterick
Same lathe but they do not name it. Not sure how you could contact.
At least there must be more than one of them.
My guess would be an old Montgomery Wards Power-Kraft just by the shape of it and tools I had way back then.
http://media.photobucket.com/user/Partsfather/media/DSC00001.jpg.html?filters[term]=wood%20lathe&filters[primary]=images&filters[secondary]=videos&sort=1&o=19#/user/Partsfather/media/DSC00001.jpg.html?filters%5Bterm%5D=wood%20lathe&filters%5Bprimary%
Bob Holcombe
It's a Darra-James Model 20. Made in the late 40's. Foster Manufacturing also sold the as Foster-Line. More info here:
http://vintagemachinery.org/mfgindex/detail.aspx?id=240
VERY Cool!
Brad Vietje
Wow, Jack,
That thing is very cool. It has such great Buck Rogers space-age styling... almost looks like a George Jetson lathe, or one that could blast off into space and orbit Saturn!
Are you restoring it for use? I'd like to know how it works... sure looks cool.
Safe spinning,
Brad Vietje
Newbury, VT
Re: VERY Cool!
Brad,
Actually,it runs as it is. I had to put a motor on it but everything was there when I got it. I got it to use for long narrow spindles. My grizzly only has one speed and it is way too fast for that application. I built a steady rest for it and with that I can turn any thickness rod I need to.---Jack
Thank you. ---Jack
Re: VERY Cool!
galen vetterick
What type of bearings are used in the headstock and how are they lubricated? What type of service did you have to do to set it up to use?
As I worked in an aluminum and magnesium foundry as a kid I think this is cool.
And my guess was way off!
walta
Cool lathe
If your lathe has ball bearings please conceder replacing them before the spindle gets damaged. The grease in the bearings will turn into a gummy mess after about 20 years. Often the bearing seizes and the shaft spin inside the bearing and that will grind down the shafts diameter. This kind of damage is difficult to repair when you do get around to replacing the bearing.
Walta
Re: VERY Cool!
I can't tell what it has for bearings without taking it apart. It feels smooth when I turn it by hand. This lathe won't be getting alot of use so I don't think I have to worry too much about bearings.All I had to do was install a new (old maytag)electric motor and rewire the switch. Someone before me already set it up for use in a handmade base. I build a wooden steadyrest for it and chucked a 30" piece of 1/2"dowel between the centers and tested it out. It will do the job.---Jack
