A55 Smoothing Plane
Getting wax off burls
Craig Daymon
One of my still to complete projects, which I posted pictures of recently, is a hollowform from an oak (pretty sure it's oak) burl. The original burl was waxed. The hollowform is complete and ready for finish, but there is still wax on some parts of the burl. For those who have created pieces like this, is there a good way to remove the wax or do you just finish it and let the wax be?
Here's another pic of the piece, before the collar was added.
Planning on using Minwax Tung Oil finish. Still want to burn the inside, which I may do using a shader in a burning pen. I should be able to reach all of it. The shop isn't conducive to using a torch. (Too small, crowded and too dusty.)
Thanks in advance,
Craig
Re: Getting wax off burls
I don't work with burls much but whenever I need to remove wax I use mineral spirits. I would think a tooth brush and mineral spirits will do the job.
Harry Robinette
Harry Robinette
I'm with John I use Mineral Spirits and a child size battery tooth brush. Brush on some spirits with small paint brush then hit it with the battery tooth brush seams to do well for me. It also saves on you wrist and fingers using the battery tooth brush.
A  Bit Extreme
But if your wax is actually Anchorseal, it will wash off nicely with a brush and warm water. I actually use an electric power washer. Lumber sealers are most all wax emulsions, so when the water evaporates, the emulsifier is still in the wax coating and reactivate when hit with water. It's best, of course, to remove the wax before you turn the piece ;)
If you want to use the mineral spirit/solvent route, I suggest you use a card scraper or similar to scrape off as much wax as the can before going to the solvent. Reason being that solvent is expensive and you'll be spreading the liquified wax into the nooks and crannies requiring a bunch more solvent to flush it out before you can apply finish with the expectation that it will stick to the piece.
steve worcester
The cheap battery operated toothbrushes are my secret weapon. But if the wax is down in the voids, flooding it with mineral spirits and using the toothbrush are a good weapon as the wax will inhibit the penetration of any finish.
The only other option is a small pencil sand blaster.
Re: A  Bit Extreme
Craig Daymon
From my experience using Anchorseal, I don't believe that is what was used. Might be beeswax or paraffin. The wax was deep in the voids and crevasses. It's possible that I could have rough turned it, figured out what shape I wanted, removed all the wax I could at that point and then finish turning it, but that didn't happen.
I'll give the mineral spirits and toothbrush a shot. I have a good stock of old ones to use, no powered ones. The wax seems to be an issue in only one area of the finished turned piece, though it is fairly heavy in that area.
Thanks to all for the help. Maybe I'll invest in one of the battery powered brushes as well so I'm ready next time.
-Craig
