Nut allergy news
I hope this OK. I copied this from a brief community news article published in Woodturner magazine. I know Mike Mahoney's says his oil is refined to remove the nut alergin and I think this article helps answer that question.
Nut Allergies- A finishing Dilemma, or is it?
This is a very important area of allergy-Acute anaphylactic attacks following nut ingestion are very alarming and sometimes fatal. The incidence of peanut allergy is now about one in 60 of the younger population.
The nut allergen is a protien and not all nut oil preparations contain that protein. This was shown in Southampton Hospital where a group of patients very allergic to peanuts were given increasing amounts of arachis-peanut oil-with no ill effect.
This is because the commercial oils are hot pressed thus releasing the oil from the nut but not releasing the protein. These oils are golden and absolutely clear.
Cold pressed oils are completely different-cloudy and often with a significant sediment that contain the allergen and that is why these oils are dangerous to nut allergic people.
The lower the temperature of the pressing the more likely it is to contain the allergen.
If what was being used to finish the bowl was completely clear nut oil there would be little chance of an allergic response even if the oils was drunk. If a cloudy nut oil was used for finishing, the important question is”what amount of oil can “escape” from the wood by contact?
By the time the bowl is dry and polished, I suspect very little allergen is available to be ingested. To my knowledge, an experiment to test this possibility has not been done. General advice on safety might be to only use hot pressed, golden and clear nut oils. Have there been any case reports of allergic people reacting to food from a bowl finished in any nut oil? I would be interested to know if there has been any such case.
Jonathan Brostoff
