NIP fiery image.
NIP fiery image.
NIP fiery image.
mjonesrdg
I was fooling around with different lighting methods to photograph this Nortfolk Is. Pine. I had put my headband with L.E.D. lights inside the vase form and took a couple of frames. I know, it doesn't show much of the turning, but thought you might enjoy seeing this aspect just the same.
Re: NIP fiery image.
Pretty cool. The best way I've found to shoot those kind of things is a spot light from up above. I use a gridded light on a boom arm most of the time. The bottom will get too hot like you see in your photo so I often put either torn pieces of black paper in the bottom or wire screen to break up the light so it's not as hot there as the rest of the piece.
