Looking for a new bandsaw
adrien
Old Rockwell died. Replacing the motor is too much for this old-timer, and no local mechanics. So will purchase new one.
Used mainly for sawing wet wood blanks, trying to make 'em round.
Suggestions???
Re: Looking for a new bandsaw
Steven Antonucci
i like my 18" Rikon.
Dennis in Southern Oregon
Just a heads up on bandsaw specs. Bandsaws generally are spec'ed by throat depth (horizontal distance from the blade to the vertical support). For many woodturning roughing out applications, the maximum cut height is equally important. Another important factor is that the table width should be large enough to allow you to trim large blanks outboard (to the right) of the blade safely.
Dennis
Price? Where to buy?
Adrien Coblentz
Price? I've seen $749 (Northern Tool) to $2,499 (Woodcraft)
Where'd you buy yours?
Sevi
I have an Agazzani 20 inch and I like it. Agazzani has beeb bought by a german company and should still be imported but I'm not sure.
In any case other italian band saws are similar and all pretty good in my opinion.
Steven Antonucci
woodcraft in allentown...think $1000 8 yrs ago?
John Scheideman
I love my Minimax MM16. Plenty of power for cutting wet logs into turning blanks. And the service from Minimax is outstanding.
As others have said...
Ralph Lindberg
Height and power... well and budget
At 14 inch, with rise and a 2 HP motor should be a consideration.
BTW, a big bandsaw isn't light. I have a ceiling mounted chainfall I use to raise things like the BS (to put it on a mobile base), the lathe and large chucks of wood.
Steven Antonucci
Wheels on a bandsaw...
steven antonucci
I put mine on by tilting it into the bed of my truck. Everything in my shop rolls except the lathe. My bandsaw is 400#, and standing it back up with wheels on is a magic trick I only performed once :D
S
Harry Robinette
Re: Wheels on a bandsaw...
Harry Robinette
I did that magic trick on my 18" Rikon and like you only once.
