Omeg stuby 1000 problem
Terry Scott
My Vacuum pump set up has stopped working as the fitting on the shaft is not sealing I beleive there is an o ring and a plastic flange that when the Vacuum is turned on pulls up against the bearing.
Any ideas how I can either fix it or adapt a way to make it work .Not having a vacuum pump is a pain in the ask your mother in law to breakfast.
I have a normal Tellis set up on another lathe but that only holds 1/4 of what my big vacuum pump does. Or did
Can I put a tube down the hole and do a hand wheel set up or is the hole that is in the shaft making this a no go.
Please make it a simple repair as I am not that Mechanically minded
Thanks in advance
