Bottom measurer. . er
Darryl
On occasion I find it nice to know where the bottom of a natural edge bowl (or any bowl for that matter) is. I made up a simple and cheeep thingy to give me the info. My lathe has a 16" swing so the lengths of the items are driven by that. I cut a piece of wood about 16.5" in length. drilled a hole in the middle. then I took some rather stiff wire and bent it into a flat "U" the top of the "U" is 8 1/4" long. The two legs are identical in length and about 10" long. The 10 " is because I rarely have a bowl that deep. I slipped a piece of gum erase on one leg to serve as a friction mechanism. Stick that leg through the hole in the wooden piece and hold the thing so the wood touches both sides of the bowl wings. The one leg goes to the bottom of the bowl the other shows me exactly where the one leg has bottomed out on the outside. The outside leg can be swiveled until it touches the outside of the bowl. I make a mark on the bowl on the outside leg and remove the "Rube Goldberg" affair. (for those who do not know Rube no explanation is possible for those that do it shows your age.: )
When I am reverse turning with my vacuum chuck first I measure from the front of the chuck face and make a pencil mark on my head stock. After affixing my bowl I just put the square at the mark and the end of the ruler shows me where the bottom of the bowl is. that keeps my from making funnels or leaky bowls.
I'm certain there are many other ways to do the same thing suggestions???
