Frozen green apple wood
Jorge
turns very nicely!
A new one to me, lots of sapwood, so it may move a lot...
I'll leave it thick, nice color.
Jorge
turns very nicely!
Re: Frozen green apple wood
Malcolm Ray
Keep it wrapped or coated Jorge,it cracks easily..........
Rob Wallace
Pretty wood Jorge!
As said before, this wood is very prone to checking. I am not so sure leaving it thick is the best strategy. (I can almost hear it cracking from here!) You may wnt to thin it down to relieve as much stress as you can, and reduce differential shrinking between heartwood and sapwood, and end grain/side grain.
Dry it as S-L-O-W-L-Y as possible. Some have reported soaking in denatured alcohol to help a bit with checking/cracking.
Good luck with keeping it together - if you do, it will be a very pretty piece!
Rob
Jim Sebring
I'm in the process of final turning several bowls of apple wood I roughed out 2 years ago. I left the walls about an inch thick for the 12 inch bowls. It was a very good thing, since they were about an inch out of round when fully dried.
After I had roughed the green bowls, I fully coated them with Anchorseal, then put them each in a cardboard box stuffed with the wet shavings. I sealed the boxes with packing tape and put them in various low-down nooks and crannies in the shop. None of the rough-outs cracked, but they did get very out-of-round.
Getting the dried bowls round again is a very unfun, white knuckle, ride, using my EWT carbide tools.
If I were to do it again, I would prolly turn the blanks thin and let 'em warp to their heart's content. Re-turning dried apple wood is akin to turning granite rock!
Gracias for the heads up!
Jorge
Mac, Rob and Jim
Thank you!
I'll make them thinner and let the do their thing.
Once and warp is the right answer for apple.
Lyle Jamieson
I know thats where the color is, but if you waste a little away off the top of the bowl where the pith is, it will be less stressful in the drying and help it survive without cracking. The farther you get from the pith the better your chances.
Another trick is to make the shape shallower. The straight sided bowl has more drying stresses. A shallow bowl will show off your color contrast better too. So in this case you would waste away some of the bottom of the bowl. It only hurts for a little while to waste some wood. This stuff grows on trees.
Thanks Lyle!
Jorge
Good point.
