Wearing glove while turning
Starry Chan
At last evening club meeting, one of our more experienced turners told the members that one should never wear glove while turning.
I almost always wear glove when turning to protect the left hand. I do not see danger in doing so as my left hand is always behind the tool rest. I do not even move the tool rest while the lathe is running. I behave the same at the lathe as at my tablesaw. Once I hit the stop button, I stay still until the machine comes to a complete stop.
Do you know anyone has had an accident due to glove wearing. If so, do you how the accident occurred?
Starry
Re: Wearing glove while turning
jim miles
jim miles
I can tell you about accidents from NOT wearing a glove.
I do almost all faceplate turning on wood waste blocks.
when turning the waste blocks round I often get large "splinters"
of wood splitting along the grain that shear off and stick into your hand without a glove.
In WT when someone tells you there is only one right way to do something, take it with a grain of salt. It probably means that they only know one way of doing things.
Dale Bonertz
Jim said it well. There has been a glove no glove debate going on for a long time. Both sides have good points. I where a glove on my right hand when rough turning bowls (I turn left handed when roughing) which helps protect it from a piece of bark letting go or unseen inclusion, knot or etc. You said it well to keep your hand on your side of the tool rest. Also when you go to feel the blank make it a habit to use the un-gloved hand so a glove can't catch on anything on the blank. I do admit that is the only time I wear a glove. Not because i am afraid to in finish turning but I like feeling the gouge, cut and etc. when finish turning and I can do that better without a glove. Note I said I and not you since these are my habits with my reasons so they may or may not apply to others.
Well they have happened and well documented. I wear a glove on my left hand when roughing although I did cut the finger tips off to lessen the chance of getting caught. The wood chips coming off hurt my left hand so it just makes sense to me.
I often wear gloves in the winter simply because my shop is too cold. When wearing gloves I do things differently than when I don't. By that I mean that I am constantly aware that I have them on and don't get anywhere near the wood. If I have to work close to the wood I take them off.
Bill Turpin in WNC mountains
My wife has turned for about 6 yrs with gloves 100% of the time. She turns small stuff, mostly ornaments, pens, and other trinkets. Her gloves are snug and close fitting mechanic's gloves. She pays about $30 for them. She has tender skin that burns or cuts with ANY contact with wood shavings. She would not turn without them. She has taken 2 week-long and three weekend classes at Arrowmont, they let her turn with them. Be careful and use proper gloves. Big floppy ill-fitting gloves with corners sticking out are dangerous. The gloves need to fit like a second skin!
Steve Kniffen
I teach graduate and undergraduate occupational safety so I'm well versed in the OSHA requirements for hand protection. Even though these rules don't apply to a home shop, they are good ideas, anyway.
I wear anti-vibration gloves when I turn anything that's out of balance and plywood. My gloves are similar to these: http://www.northernsafety.com/Product/10133/Valeo-Anti-Vibration-Half-Finger-Sueded-Leather-Anti-Vibration-Gloves but I get them from Harbor Freight. They help dampen the vibration while I get a block of wood in balance and they deflect small splinters.
I also do the other things that have been mentioned - keep fingers on my side of the tool rest, don't adjust things with the lathe running, and making sure the gloves are tight on my hands. Since these gloves don't have fingers in them, I've still got the ability to feel for smoothness.
Steve
Lyle Jamieson
Lyle Jamieson
Another reason to cut the fingers off is that sawdust/shavings get into the glove and settles in the fingertips. Little slivers/splinters of wood down in the fingertips are not very friendly.
barry rockwell
barry rockwell
I ALWAYS wear a snug fitting cowhide glove on my left hand and sometimes on both hands. I once had a bad catch while turning a large rough piece of timber and the tool handle smashed my hand into the spinning timber. It crushed most of the soft tissue in my left hand but fortunately broke no bones. Without the glove in tould have certainly taken everything off the back of my hand down to the bone, and I could have bled to death. As it was, it didn't break the skin. I had to cut my wedding ring off with a pair of dikes, and had a very sore, swollen hand for months, but no blood. Yea glove.
Jorge
Starry,
I work in a non heated space, only 6 mil of polyethylene between me and the north wind in Maine, so I use gloves to be able to use my hands and do not cut the tips of the fingers, when I need to feel the piece or the edge of my tool, I take the gloves off.
Once the weather is benign, no more gloves unless I am roughing out.
Other shocking things happen when you don't have a heated space: the faceshield fogs and freezes, the dust mask clogs and freezes too, no way to use a compressor or vacuum pump, so the range of activities is restricted and the finishing stages of a project must wait for better weather.
One does what one must.
Barry L Elder
I am aware of the many accidents that can happen in a home shop. But the fact is that many of us don't like to admit that our BRAIN is not operating when we have most of our "accidents". And if you think that the former liability insurance available to the AAW for the clubs suffered from skyrocketing rates because of rocks passing close by the earth.........
I always wear a good leather golf........
JamieDonaldson
...glove on my L hand while turning, and that thin white hide is tougher than my thin white hide! I've also developed a habit of grabbing the outboard handwheel to help slow down wood spinning to a halt, and you don't forget the glove when doing that! ;) I've seem "expert" turners place their hand against a spinning chuck or wood blank to help slow it to a stop, and recall that someone had a finger slip into the chuck key hole and sliced the finger right off! Oouu, hurts me to even think of the potential hazards there!
Bernie Weishapl
I use a fingerless weight lifting glove. It has a padded palm which helps with vibration especially when roughing. On smaller turnings I use a golf glove.
Steven Antonucci
Only for roughing (personal choice)
Not,  personal choice
Dick Hines
Re: Not,  personal choice
Dick Hines
I have been wearing gloves for years. I don't like the hot chips flying into my left hand. The help dampen the vibration of the tools too.
I cut the finger tips off as soon as I get them. I like the tight fitting work gloves better than loose fitting gloves.
Darryl
I did use my fingerless sailing glove for a while. Then the kids bought me some "Ironclads" they are great. They have a tight fitting "spandex" type body. non slip palm and vibration dampening palm and velcro closure at the wrist. No way could they be tangled with the turning if the hand is where it is supposed to be
Terry Scott
I have a pig skin clove that I have cut out the fingers on
When Iam turning hard burl the chips that come off will sand blast my hand until blood flows
Recently I brought a pair of expensive neopreme riggers gloves note to self dont try and grab a bowl or the handwheel as the grip on this stuff has no slip
Mark ravensdale
I was using the beal buffing system one day and some how I managed to get my hand stuck between the lathe bed and the rotating buff (the one for the red buffing bar) which was turning at 1725rpm, the buff buffed it's way straight through my skin and into the flesh of my hand before I even realised what was going on, and I still have the scars to prove it, I sure wish I had been wearing a leather glove that day, it took weeks to heal and was very painful (it wasn't a cut but more of an abrasion/burn)
Harry Robinette
Harry Robinette
I use pig skin gloves mainly on my left but sometimes on both.They are a tight fitting glove and I cut the complete finger out I use a over hand grip and the flute bothers my palm.
Bill Blasic
Bill Blasic
I have used a golf glove ever since Jamie's visit a few years back. It is a lot more comfortable than the weight lifters glove that I previously used.
Bill
Daryl
Richard Jones
Daryl,
Do you happen to know which model of Ironclad you have?
Thanks.
Rich
Re: Daryl
Darryl
Rich, there does not seem to be a number that I can see. On one glove there is a tab that says" Tack box Palm".
But then my turning would be as bad as my golf
brushed a knuckle against the grinder
It only cut a small mark but really hurt and tool way longer than other cuts to heal. Not fun.
Cyril Griesbach
Like Bill, I too wear a golf glove on the left ever since Jamie was here a few years ago. My old golf glove goes from the bag to the turning smock when I get a new one.
