Oneway 1640 or Robust Liberty
sevilla
Hello everybody, I have now a Jet 1642 2 HP which runs very smooth and has a very good point to point alignement (perfect on the orizontal axis and 1/32 off on the vertical). This is impotant to me since I often use a chuck also on the tailstock. There are a few poblem though I ecountered with this lathe that are pushing me to change it and buy another one as soon as I found a buyer for the jet.
Firts, when I work on the back of bowls or other pieces, which I often do, I tend to accidentally tuch the electric controls and change the speed or turn off the lathe. A couple o time I even put it in reverse. The controls have no protection and are in the way of my movements.
Furthermore, the banjo is not the strongest, and under certain condition it tends to get loose.
I do not know if there is a solution to these problems but my inclination is to buy a new lathe. Since sixteen incees if good for me, I'm coonsidering the Oneway 1640 or the Robust Liberty. The sweet sixteen seems a little complicated for my taste.
The Liberty seems rather light at about 320 lbs as a bench lathe and 380 with the legs, version that I'm considering.
Any experience with these two lathes and recommendations or inputs?
Thank you very much.
