Pencil Mightier Than The Spear
charlie belden
About a year ago, either here or on WOW, I saw a tall narrow hollow form out of burl that had been dyed with bright colors. The piece evoked a tall slender African woman in traditiohnal dress in my mind. I filed the idea away for future use - an idea that could be an interesting multiple axes piece. Months later I started some sketches, fleshing out the idea a bit more. The iconic image of a Masai herdsman came to mind and I played with that idea. More sketches and then some 3D modeling in SketchUp to work out where the centers of the axes to be used should be placed.
Time to turn some wood. Unfortunately, the first attempt was done with fresh cut Mimosa. Wet wood means HEAVIER, and when you're turning "off center", that means more VIBRATION at higher rpms. Turning off center at low rpms means MORE opportunities for CATCHES. Add in that mimosa is a relatively soft, open grained wood and you have a recipe for failure - which is what happened. Two pounds of spinning wet wood coming apart can be quite "stimulating".
Going with "If at first you don't succeed, and you aren't killed . . ." my second attempt was with dry pear wood. A bit denser than mimosa and a bit lighter since it was dry, and tight grained, it turned with much less White Knuckling and Clenched Jawing.
Having most of the turning done, and having added a TWIST to the torso's covering, I found some differnt diameter dowels to try as the Masai Herdsman's spear. The dowel diamters I had were either too small or two big. Having a lot of sharpened #2 pencils around, I tried one of them - and got an off the wall idea to play on The Pen Is Mightier Than The Sword -"The Pencil Is Mightier Than The Spear" - a more African take on the old EuroCentric maxim.
So here's how the piece has gone. About 10" tall and 2 1/2" at its widest.
Have a bit more turning to do before I start carving, texturing and coloring - but - So Far, So Good.
Comments, questions and suggestions welcomed.
Re: Pencil Mightier Than The Spear
Jim Barbour
Jim Barbour
Thus far I like it. I particularly like the idea incorporating the pencil. Anxious to see how it works out as a finished piece - as you say, so far - so good. Keep at it.
~ jim
Joe Herrmann
Look forward to seeing this as a finished piece.
