Mallets
Mallets
Mallets
Joe herrmann
Someone suggested that I do a carver's mallet along with the regular one so I came up with this one. It's maple and was made from a blank that Bill Blasic gave me.
Re: Mallets
Mike Stafford
Re: Mallets
Mike Stafford
That is a classy looking carver's mallet. Too nice to pound on chisels with....
Love the shape!
Re: Mallets
Re: Mallets
Tom
What did you use for bands? Tom
Re: Mallets
Re: Mallets
Mark ravensdale
Joe, I have a bit of a mallet fetish I think, I seem to turn 4-5 every year, anyway I like this pair especially the bottom one it has a nice pleasing shape and looks like it would be nice in the hand, I also like the added details that lift it from just being another mallet, nice work joe, keep it up !!!
Re: Mallets
Re: Mallets
Joe herrmann
The bands are 1/2" wide pieces of 2-14" ID aluminum pipe.
Re: Mallets
Re: Mallets
Dick Coers
The shape of the new one is pleasing to the eye, but I'm not sure it is practical. I've always turned a straight taper, assuming it would contact the chisel at the angle of my wrist. The sweeping curve may contact the chisel at some odd angles, changing the angle of attack at the wood. Only some good striking time will tell. I guess I'm assuming this is a new shape for you. Do you already have experience with it?
Re: Mallets
Re: Mallets
Tom
Thanks, Joe. Appreciate your reply!
Tom
Re: Mallets
Re: Mallets
Joe Herrmann
I made one years ago but used it mainly for wood chisels. It worked OK.
Re: Mallets
Re: Mallets
David Walser
Joe,
I love both mallets. I suggest you consider making the carver's mallet with a flat top. That will allow the user to stand the mallet up on the bench.
Re: Mallets
Re: Mallets
phillip medghalchi
Joe, is that red oak mallet made of one piece solid oak or did you glue two or more pieces together. I had lots of scrap 3/4" pieces that I got them from a cabinet shop and tried to glue them together and tried to make a mallet out of them and ended up that once on the lathe or off it it came off and broke on the grain so I ended up using maple pieces. Or do think that scrap pieces from a cabinet shop are to dry (kiln dried) for turning pieces?
Re: Mallets
Re: Mallets
Joe Herrmann
Phillip: It's difficult to get kiln dried oak in thickness greater than 2" because of the difficulties encountered in the drying process. I glued several pieces together to get the 4 or 5 blanks for the mallets I've made so far to perfect the process. I do a lot of flat work too and the blanks were cutoffs from leg blanks that I made. I've never had problems with gluing up the KD oak that I use.
Re: Mallets
Re: Mallets
phillip medghalchi
Joe, I wish I could figure out what I did wrong that the darn thing didn't hold up. I see if I still have it and take a pic. of it.
Re: Mallets
Re: Mallets
Joe Herrmann
It might not be anything you did wrong--Oak is just temperamental sometimes--and a lot of folks don't like to work with it for some reason. I got a load in once at school that was all honeycombed because of improper drying--perhaps that might be the reason you had problems?
Re: Mallets
Don Leydens
Re: Mallets
Don Leydens
Love these, Joe. On one hand, they look too good to use, but on the other, you just want to pick these up an whack something. They look like they would have a very good feel to them in your hand. Sweet.
Re: Mallets
Re: Mallets
Devon Palmer
Sharp. Love the banding and the detail.
