The patient is on life support
Steven Antonucci
steven antonucci
Took a looksee when I got back from Raleigh last night at the platter aforementioned. It does not look good, as there is a definitive crack developing.
Will have to see what happens in the long run, but it may end up being an "art piece".
Steve
Re: The patient is on life support
HA!!!
No soup for you!
[ :D ]
Galen Vetterick
Now will you send the $20 cause I knew it would crack. :D
phillip medghalchi
where is the platter aforementioned, and who is cracking in the hospital? :D
Steven Antonucci
Re: The patient is on life support  *LINK*
reference
Don in Central Illinois
My teacher taught me, if ot holds soup it's not art.
Chip in Plano
Can you just cut through the crack, sand the two halves to mate nicely....glue it....and call it a football-shaped platter?
Steven Antonucci
Here is a picture
steven antonucci
Last weekend:
This weekend:
I will say that the donut chuck idea worked at keeping it flat, but I think you almost need to turn a ring to keep it from going oval too? It was flat when I took it out, but you can see how much it shrunk across the grain vs. elongating with the grain. I suspect that movement is what tore it almost in half. If it was resrticted in a round recess, I think it would dry OK?
I never expected it to work, so I don't have anything bad to say about the experiment. One less thing to sand...
Steve
Allan W
Re: Here is a picture
Allan W
Would a strap clamp work to keep it together? Another possibility might be some large hose clamps around the outside. I noticed that a turner in Alaska used them to hold his segmented pieces together when he was doing glue up.
Steven Antonucci
Thought about that.
steven antonucci
I'm OK with losing a piece in the name of science (sort of OK, but also sort of not OK...if you know what I mean?)
I know that it wants to move, and I was interested in trying to see what would happen if I didn't let it move. I think it actually cracked more than it would have if I had just let it move? I may try it again with another piece of wood and restrict it further to validate my theory. Sometimes in life, you just need to go with the flow and realize that you cannot control things and you take what you get...
I have a pile of these, so it is no big surprise... but more a reminder of something I already know.
Steve
Son of a Beech!
Don Orr
Tore itself up alright. Nature of the beast.
Re: Son of a Beech!
phillip medghalchi
Steven, I had a walnut piece long time ago that everyone said to toss it remember? It opened up badly then what I did I put it back in abed of shavings (coarse) and left it alone for few months. I checked it recently and the crack came to gether very closely, so what you say to do that and leave it alone for few months and see what happens. what you got to lose and in the interim you may learn something too?
Steven Antonucci
way ahead of you
Re: way ahead of you
phillip medghalchi
I thought I just suggest it. Didn't realize that you were an expert, already.
Steven Antonucci
It's not going to work in this case...
steven antonucci
Took it out again to check last night, and the piece is 1" longer than it is wide (14"x15"), which means it's moved 1/2"...which explains the 1/4" cracks!
I may do a DNA soak on the next one before binding it. This one is probably going to the firepit.
Steve
