Oneway Coring Help
Oneway Coring Help
Oneway Coring Help
Roy
I got a Oneway coring tool from a friend that was meant for a 12" lathe. After consulting with Oneway, I made a 4" riser to allow me to use this tool. I was also told that this tool only comes with one cutter which has 3272 stamped on the cutter arm.
I've cored before and am comfortable with the process and my question is, "Can I cut more than one core using the same cutter?" My immediate thought is "no" but I wanted to post the questions to you experts. If it is possible, what's the process?
Thanks in advance for your responses and help.
Re: Oneway Coring Help
Greg Haugen
The answer is, "Yes". You can make different sized cores, and multiple cores with one cutter. When I travel and demo the system I'll only take the #1 knife. It's easier packing less tools, and the majority of Club lathes fall into the 16" to 20" swing range. The #1 knife is the great size to make a nested set of 3 bowls (including the large bowl-so 2 cores cored for twice turned bowls out of a 12" to 14" diameter blank that's 4"-5"). By simply moving the base forward or back, and side to side you can change the point of entry and the depth of cut, thus making multiple cores with one knife. There is a range of movement to work within, the captured radius-ed knives can only go so deep or wide.
If that said, it sound like you're using the 12" lathe system that has one cutter and it slides over the base, where as the larger systems' knives fit into a tool post. I haven't used that specific knife. I'm not sure if it's comparable to the standard #1 knife of the larger systems or if it's smaller.
When sharpening the cutter tip, the jig for it that Oneway has is excellent. Honing doesn't do enough. I light "dressing" on a grinder is what is needed.
robo hippy
I do have that blade, and have only used it a few times. Sharpening those tips is a pain for me, and I don't think I ever got it totally right. The 12 inch lathe blade from Oneway can remove multiple cores. The way to do it with that set up would be to move the tool rest/plate away from the bowl blank and take the smallest one first, keeping the tool rest pretty much centered on the ways of the lathe. Move it in closer for the second one, and in closer yet for the third. I would suggest doing a drawing of the bowl blank that would be a rectangle. So, 12 inch diameter blank and 6 inch deep would be a rectangle 12 by 6. Mark the center line. Take a compas, set to a 6 inch radius, move it out onto the center line and draw the arcs of the circle. Probably start with the biggest one first. Make sure to account for bowl wall thickness, and kerf/width of cut. Move the pivot point out to draw the second cut, etc. This will help you figure out how far to move the tool rest for taking the cores. You can move the tool rest a bit side to side, but not much. This will change the angle of entry, but if you go much off center, you may have to open up the kerf a bit wider so you can get both blade and support finger into the cut. For a 6 inch deep bowl blank, you can get 2 cores without too much trouble. For me, generally I would only take 1 or maybe 2 cores from a blank that size. The smallest pieces are often not worth the effort. I did find that the 12 inch lathes can be used to core, but generally are underpowered for this type of work. Actually, for 12 inch lathes, the mini McNaughton, or the Woodcut coring system work better.
robo hippy
Roy
Thanks for your help. I think I'll try your suggestions on paper with a compass before attempting it on wood. It makes sense and your explanation was very straight forward. I using the coring tool on a Jet 1642EVS with a 4" riser block bolted to the lathe bed. Thanks again.
