REAL MILK PAINT
Sanding hack - might be worth a try! *LINK*
Re: Sanding hack - might be worth a try! *LINK*
waltben
Does look interesting, but won't particles of the plastic end up in the wood?
matt overton
Thanks Leo, this might be great for jam chucking odd shaped pieces. I ordered some. I'll let you know. MAKE is a great source, I missed this one so thanks for pointing it out.
Leo Cuellar
Leo Cuellar
I haven't ordered any yet to play with, but I will in a couple of weeks. I've heard that it is very tough stuff as long as you don't get it near the melting point.
Leo Cuellar
Leo Cuellar
That is a great idea! I hadn't even considered that. If you covered it with some friction tape, you'd probably get a real good grip as well.
Jerry Louden
Jerry Louden
What would you use as your source of grit?
Leo Cuellar
Leo Cuellar
While I haven't had time to research, loose grit is available in the form of sand blasting media, rock tumbler & valve grinding compound to name a few. Or another use might be to shape a custom profile in the plastic and just glue a piece of sandpaper to it?
I also wonder if you were to solder/weld/attach some wire or a disc to an old arbor if you could form the compound to make a low speed power sander?
