200+ woodworking book reviews
Diamond-plated Grinding wheel
Dick Hines
Dick Hines
I was just looking through the latest Enco sales catalog. They have diamond plated wheels for as little as $83.99. There two sizes 6" X 3/4' thick X 1" face and
6" x 1"thick x 3/4" face. They come in three grits 100 150 220.
Though someone would be interested.
Re: Diamond-plated Grinding wheel
Dick I saw those also but after talking to Dietmer Holzer of Optigrind I definitely ruled out diamond wheels. I've heard from other turners that they don't hold up and wear out quickly. Deitmar went into more detail about why and convince me that the CBN wheels are the way to go over diamond.
Don Leydens
Don Leydens
I have to agree, John. I have both wheels and the diamond wheel just sits in a tray collecting dust, The CBN wheel is one of the best woodturning investments I've ever made.
robo hippy
Diamond is fine for carbide, ceramics, glass and stone. Not good for steel. That is why there is CBN.
robo hippy
JoHannes Michelsen
It's true what john said CBN is where it's at, Dietmar of OptiGrind
Makes it clear on the sheet that packed with every one of his
Fine Austrian made C N wheels.
Diamond wheels can't stand the heat of dry grinding 170 degrees
centigrade is all it takes to ruin a diamond wheel while CBN can
with stand 700 degrees C. So diamond is fine in a machine shop with
cooling liquid but not for the Woodturner doing dry grinding.
Check www.hannestool.com and give me call I have OptiGrind wheels
in stock for you!
Dick Hines
Dick Hines
Not planing on buying one of these. Just thought someone would like to know they were out there at a good price.
I am perfectly happy with my blue Norton wheels.
Ralph Lindberg
Dick
That's because you haven't tried a CBN :D
True story, last summer the DW and I were talking a 2 day class from Eli Avisera. At one point she walked over to the sharpening station (which was two D-Way CBNs) walked over to me and said "as soon as we can afford it, we are getting one"
She got a 180 grit for her birthday
Eli stated "Dave has changed sharpening forever"
The only person I have talked to that doesn't like the edge they give is Mike Mahoney, he prefers a more jagged edge
(Dave of D-way is a member of our local club)
The biggest problem with the CBN wheels is the price. Diamond wheels are cheaper but still kind of expensive and don't last. The friable wheels that most of us use wear down fairly quickly but they are pretty darn inexpensive.
What I'm trying to learn with all these tests is not which one is better, I think most of us agree that a sharper edge is better so if can sharpen with an 800 grit belt or 1000 grit wet wheel then in theory that would be better.
There are so many other factors however when you look at the total picture on sharpening and none will fit every person. Personally I think the CBN will take over because it's a good system and most turners seem to have money to spend. `
robo hippy
CBN will replace the standard matrix wheels. Main reason is that they out perform the standard wheels in every single category, from being safer to cutting abilities. Even at the price, they are a much better value, and will out last by far any comparable $ amount of any other wheels you can buy. Add to that that you can toss your diamond dressers and truing systems, and it gets better. When you try them, you will understand.
robo hippy
joHannes Michelsen
CBN wheels are a wet dream come true---really!!!
there just isn't even any comparison they are truly amazing, of all the attributes which I won't go into cause its a long list the best one is they are perfectly round which makes it possible to do a super light lick to "just" sharpen a tool w/o wasting any steel trying to "stay" on an un-round matrix/stone wheel. Consequently even if the CBN doesn't last as long as they are reputed to the savings in steel alone will more than pay for the wheels.
Dick Hines
Dick Hines
I guess the diamond wheels are like a electric car. I will buy one when they take the keys to my V8 pickup out of my cold dead fingers.
CBN life...
Ralph Lindberg
Dave at D-Way has been using the same set of CBN wheel for three-four years, doing all of his tool grinding to shape and sharpen all the tools he is selling.
Makes me think that for -my- usage, it may be a lifetime item.
Re: CBN life...
joHannes Michelsen
Ralph, you are right on and Dick you are surely missing the boat on this one, CBN is a V10 and your blue norton wheels are a stanley steamer!
phillip medghalchi
John, I've seen what it does and I think I have to wait until way too many other turners buy it at the current price that it will come down in the price so it'll fit my budget, right now it's little too much to acquire it.
Mark ravensdale
Diamond is fine on carbon steel and will grind HSS but at slow speed (like on a tormek wet wheel system) but on a high speed grinder CBN is the way to go (I have one and they work great!!!)
