My first try at Small Bowls
Allan W
Allan W
I had a couple of smaller pieces of my Box Elder that I decided to try and turn into bowls. Here are the results. Each bowl is 4 inches across and 2 inches high. I am still having issues with the end grain having small tear outs, even using a scrapper. The scrapper has helped with the tear out but not eliminated. I have looked at the Carbide Cutters, but just have a hard time putting out that much money.
Re: My first try at Small Bowls
Re: My first try at Small Bowls *LINK*
Don't fret over it. Box Elder is one wood that is hard to cut clean without tearout. Carbide cutters aren't the answer to tearout. Sharp tools presented to the wood at the proper angle are the solution. It takes time to learn that but we'll try to help. I am going to make a video on using the bowl gouge to try and help out but it will probably be a month or more away. I'm pretty busy right now.
You might watch some of my other videos. The ones on turning beads and turning coves are good. Using a bowl gouge isn't much different. A bowl is more or less just a big bead and cove.
Go to Youtube.com and type in John60lucas and you will find them. I'll post one below.
Now that I think of it the video on the Osprey tool is very similar to a bowl gouge except you can't do the scraping cuts with the bowl gouge.
http://www.youtube.com/watch?v=lfZsH-Xprtg
Lyle Jamieson
Lyle Jamieson
Allan, you have a great start going there. Keep at it, each one gets better and easier. You have started out with very difficult shapes. The steep side wall and corner in the bottom are very advanced shapes to tackle. I suggest you start with a shallow bowl with a constant flowing ark of a shape on the inside. The trick is to start on the outside to make a shallower shape and then follow it on the inside to keep a uniform wall thickness. A good shape for the inside of a bowl would be a football shape. The line of a football has a steady uniform ark, no undulations, no flat spots, just a sweeping shape. After you master some shallower shapes then you can have an easier time with the deeper bowls.
The torn out grain is something we all have had to deal with. The shallower bowl will be easier to sand, if you do have some torn grain. Here is my YouTube clip on the cuts I do to prevent torn out grain. http://youtu.be/qnym1IyOPgE This one talks about grain issues. The four cuts I use are defined on other clips. You can see all 40 clips on my YouTube channel. (Im trying to catch up to John Lucas with hits on my channel :-) Sorry I have not figured out how to get this to be a link so you need to copy and paste it.
Joe Dickason
Allen-I too have been working recently with some boxelder. The last I roughed close, then soaked with 50/50 alcohol/deft. Seemed to cause it to hold together better. Not totally proven, but was convincing enough I'll try it again.
Allan W
Allan W
Thanks. My main concerns are on the inside surfaces of the bowl. If they are used for food that is not wrapped, it could be a problem keeping them clean. I have had some luck with spraying them with a clear coat, then sanding. After about 4 to 5 coats, the inside finish smooths out pretty good, but not as good as I would like. The box elder is my first attempt at turning bowls and cutting a log into blanks. The rough finish on the outside gives the bowl character since most of the bowls from this log also have some of the back left on them.
I am now waiting for the snow to melt so I can claim the cherry log that was given to me. Right now it is under about 4 feet of ice and snow at a school parking lot.
Allan W
Allan W
I just finished one bowl and one vase. They had less tear out then my previous bowls. I did purchase a bowl scraper and have been taking lighter cuts with it, then I sanded with 150 grit sand paper before I put finish on. I also took the time to sand the end grain areas by hand. I finished with Minwax water based finish (this time I read the directions and "followed" them). After the last coat, I sanded lightly with 320, 600 and then 1000 and finally buffed lightly with a cotton cloth. They both turned out much better than any of my other finishes. After the first coat, it took a little more sanding to get the grain back down, but after that, it was not a problem. The picture does not do the vase justice, but is best I can do right now. My camera decided it would quit working after I took this photo.
