200+ woodworking book reviews
Hollowform with holes - sanding inside?
Craig Daymon
I'll be getting back to a hollowform I turned from a burl, I think White Oak, that has some pretty good voids in the sides. It's off the lathe now and the bottom is turned. Still needs a collar.
I would like to sand the inside a bit before applying a finish. Any suggestions on the best approach?
I followed the curve pretty good, but it's rough inside. It's about 4" tall and 9" in diameter. One of the voids is over 2" wide.
Definitely needed the face shield when roughing...and gloves. Face is safe, but a couple fingers are healing from some nicks. I'm not a great hollowform turner, but it turned like sticking a tool in a bag of rocks. I'll post picks when it's done.
Thanks,
Craig
Re: Hollowform with holes - sanding inside?
john Veerkamp
I sand these type on the lathe using a flap sander if I can't reach it another way. My flap sander is a dowel with a kerf. I cut strips of the appropriate grade paper, insert in the kerf and sand away. Off the lathe this approach also works if you chuck the dowel in a drill. Sand gently so as to not round over the edges of the voids too much.
Dick Hines
Dick Hines
As a joke I did this to one of my hollow forms. Now no one will ever know if it sanded inside or not. The trap works too.
I don't sand the inside of my hollow forms. Will take a scraper and work around the opening.
Craig Daymon
I'm planning to put a collar on it. I thought about putting a lid with a lock as a joke since the holes in the side make even a lid pretty pointless.
Here's a pic of the piece, no finish or collar (or locked lid) yet.
-Craig
Craig Daymon
If it was still on the lathe, I'd be using scotch-brite held in a pair of long hemostats I have for this purpose. Unfortunately, I wasn't thinking before I took it off.
I'll see what I can rig up. Thanks.
I had also thought about whether it would be possible to torch the inside. Thought it might look pretty cool on a piece like this. Wondering if there is a torch head with a flexible shaft. Anyone tried this, especially with one with voids like this?
jim miles
jim miles
try a 2 - 3" flap wheel sander in drill - mounted in drill bit extension- they usually come in 6" or 12"- put PVC pipe around extension so you can hold it while it turns. ( would post pic- camera not working )
Brad Vietje
Brad Vietje
Craig,
I figure if you can touch it, I should sand it.
I have never scorched the interior, but I have used flat black paint, and then very carefully sanded the outside to keep the edges crisp. If you very carefully cover the entire outer surface with a good quality tape, you may be able to avoid any contamination from the paint.
I also like to carefully scrub the decayed areas with a brass bristle wire brush to show the texture and pattern of the exposed wood fibers. Then I'd be careful to polish and/or buff the smooth outer parts without getting any finish into those decayed areas.
I hope you post photos of the end result.
Safe spinning,
Brad Vietje
Newbury, VT
