grain filler
g clarke
Any suggestions for filling the pores in wenge?
grain filler
g clarke
Re: grain filler
terry
I use lacquer sanding sealer, sand, respray, sand and continue till you get
the look feel you want
Re: grain filler
g clarke
terry, have you done this on Wenge?
Re: grain filler
I have not done it on Wenge but have done it on other woods with pores as deep. It does take a lot of coats. High build finishes make it faster. I've played a lot with Birchwood-Casey's true oil. It builds quickly and works wonderful for this.
I have used grain fillers to fill woods like Oak and Walnut. In those cases I used a commercial filler and colored it to match the wood.
Re: grain filler
Curt Stivison
I use Tru-oil on my turkey calls and it builds in 3 to 4 coats and ends with a very durable finish.
I haven't done it on wenge...
GaryG in MD
You may be implying that wenge is a special case, in which my comment may not make sense, but I would think that wet sanding at, say, 400 with a high-solids oil like Bush Oil would do the job and keep the same color profile. ...GG
Re: grain filler
terry
Yes, I have used this on Wenge takes 4 or so applications, but is worked for me
Re: I haven't done it on wenge...
g clarke
I do not mean to imply that wenge is special. It is just that I have some for segmented turnings and would like to get rid of the pores that I have had difficulty. I will be experimenting with it until I find a good solution that works for me. I will start with John's suggestion and go from there. Thanks to everyone for your input. When your too old to learn your dead.
The method I use for a glossy finish on segmented turnings that have all sorts of woods is the same as I use for really glossy. Apply finish, sand or steel wool it off until you only see the shiny areas in the pores. When you have enough coats of finish to fill the pores the sanding will leave the entire vessel matte looking. apply one or two more coats and your done.
With oil finishes this can take many many many coats. With low build finishes quite a few coats. Thicker finishes like the Birchwood Casey True oil usually between 7 and 10 coats get it perfectly flat and ready for the final finish. Of course that depends entirely on the depth of the pores.
Pore fillers are designed to speed up the process by filling the pores however for our purposes you have to color the filler either to match or a contrasting color. Either one can be kind of a pain.
GaryG in MD
Wet sanding would definitely NOT be for segmented turning. It would smear the dark wenge goo all over the lighter woods. Segmented turnings need to be heavily sealed first to prevent that kind of bleeding over. ...GG
I didn't say wet sanding.
I put on several coats of finish and use 600 grit dry or 4/0 steel wool which is what I use mostly. This is done to mostly remove finish so 90 percent of it is left in the pores. What your trying to do is 2 things. One is to level the finish and second is to fill the pores.
If your dealing with contrasting woods in segmented work the very first thing to do before you ever touch it with sandpaper is to seal it. I seal between every coat in that instance. Applying a sealing coat helps fill the pores so the contrasting sawdust doesn't fill them up. It won't really fill the pores in the early stages but seems to make it easier to blow out the offending dust.
just correcting my statement...
GaryG in MD
Sorry John -- I was correcting my own statement above about using wet sanding to fill the grain of the wenge. I said that before finding out that we were talking about segmented work. ...GG
