Thoughts on a Vega Lathe Duplicator?
Joe Pack
I have a chance to pick up a Vega D48 duplicator. I have never used one. Any thoughts on this accessory?
Joe Pack
Re: Thoughts on a Vega Lathe Duplicator?
phillip medghalchi
I am thinking.
It works really well. It does take time to set up so you really need to be able to turn multiples or if you have a second lathe leave it set up. You will need a model to copy so you either have to turn the first one or you can simply build a model out of hardboard or plywood for the follower to copy.
It cuts really clean if you cut down hill with the grain. The #1 misconception is you just cut from one end to the other and you have a perfect copy. Well you can but it leaves rough edges when cutting up hill. Make a passes taking off the larger amounts and then go back and make passes going from the high points to the low points.
The Carbide cutter is worth the investment. It cuts much cleaner and of course stays sharp far longer.
There are some cuts you will have to do by hand if your design requires these. Because the cutter is V shaped you can't cut a square shoulder on a bead or at the back of a tenon. I mount the tool rest backwards on the lathe and then walk around to backside and turn the lathe in reverse to clean up these areas.
Dick Coers
I have the mini with carbide cutter. It will never cut as cleanly as my hand, and not cut the fine details. I mount mine on the back side, cutter upside down, and leave the banjo and tool rest on the front. It lets me clean up the spindle after shaping to size. Mine has about a 1/4" of dust on it, because I don't use it very often.
I got cuts clean enough to use 220 grit with mine using the carbide cutter. Again I was cutting down hill with the grain for all final passes. I also found that there is just a tiny bit of flex to the system. I use this to my advantage. On the last pass I push on the machine a little harder. It takes off a very small amount of wood and leaves a surprisingly good finish.
Dick Coers
So you are saying it cuts as clean as a skew?
No not as clean as a skew but if used correctly very clean. Besides on many spindles you may have details that are difficult to turn with a skew, such as coves. I can turn some coves with a skew.
What I'm really saying is with a good duplicator most people can turn duplicate spindles faster than they can by hand and clean enough for most uses. I can turn my mirror handles faster and cleaner than I could with a duplicator but I've done hundreds. If I needed to turn 20 ballisters which I don't turn all the time I could do it much faster with the Duplicator, and every one would be exactly the same.
Price?
Joe Pack
What would be a fair price to pay for the Vega48, assuming reasonable used condition?
