Kelton Multi Axis Scraper *LINK*
Barbara Gill
I haven't been very active here or at the lathe. I expect that to change once I get my second knee replaced and recover.
I noticed a thread on scrapers below and decided to put my two cents in about the Kelton Multi Axis scraper. Before my knees got so bad I was loving using this tool. I am one who has always been scraper challenged. With the MultiAxis I had wonderful success.
I am providing a link for anyone who is interested. It is very informative and does a much better job than I at describing how well this tool works.
Kelton MultiAxis Scraper Link
Re: Kelton Multi Axis Scraper *LINK*
robo hippy
I did look at them when Kel first came out with them at the AAW Symposium 2 years back in Minneapolis. I just couldn't see that it would do anything that I couldn't do with a standard scraper. I do use standard scrapers a lot though.
I have wondered about the tear dropped scrapers, and how they would work as a negative rake scraper. I have only tried using them to clean up the insides of hollow forms, and found them to be very grabby. A negative rake would take care of that problem. Kel's version would not work that way because of the veneer of the hard steel that he puts on top of the main body of tear drop scraper tip.
robo hippy
GaryG in MD
I shouldn't speak for other people, but since I was personally introduced to this by Paul, I think it's fair. Paul Fennell uses a similar multi-axis scraper of his own design with a large teardrop scraper blade on a round shaft to make finishing shearing cuts on the exterior curvy parts at the necks of his hollow forms. He gets those wispy curls that say you're doing it just right. I believe he does it on both green and dry woods, but green for sure. He made a believer out of me. A "normal" scraper would technically work, but the handle would have to be in a very awkward (or impossible) position, so an ad hoc tool like this provides added utility and comfort, as well as added flexibility to work at different angles all around the curve without moving the tool rest. ...GG
Mark ravensdale
I have one of these scrapers, when I opened the box I thought wow that's bigger than I thought it was going to be, I don't tend to use it on the smaller stuff I turn, but on my larger projects it works very well, and it holds it's edge better than any other scraper I have, I only really use it as a shear scraper but maybe one day I may have need to use its neg rake capabilities !!!
