Problem with thread chasing
When I was doing the demo in Arizona I had a problem with the thread going on a sort of tilt. I think some how half a revolution around it skipped a tooth so the thread jumped. At this point it's impossible to correct it. I've had this happen twice in the last dozen ornaments. Anybody got any ideas. Maybe I'm pushing to hard at the start of the thread. Once it starts I try really hard to let it pull the cutter.
I have also had a problem one time with the thread getting a second start so I have a double thread. It threads on perfectly but will be 180 degrees out when aligning the grain. Screw it off and start again the the grain will align perfectly. I think this is simply a problem of the thread starting itself in 2 different places as you first start the thread since your going in and out of the cut. My rhythm must be off but then if you saw me dance you wouldn't even question that.
