I've been busy making dowels
I have a project I'm trying to finish for a friend. It needs 4 3/8" by 32" dowels and 3 5/8" by 34 1/2" dowels. I've got all but one done. I need more wood. One 3/8" one broke while cutting it so I had to make another one and only had enough wood for all of them. OH well, meeting a friend in the morning who may have what i need.
I make these using the router. You make a jig with a hole in one side that accepts the square dowel. Feed it past the router bit using a drill so it goes into a hole on the other side that is the size you need. It takes a little fiddling to get it right. My dowels were about .010" oversize at the max after sanding. I had to enlarge the holes in the brass they will fit in just a hair with a reamer. The 5/8" dowels are dead on. It would have been impossible to turn these. I might have been able to do the 3/8" dowels a little at a time but it would have taken forever. The 5/8" would not go through the headstock so that was out of the question.
While making these I did get some nasty tearout here and there. relatively small stuff but would show up like crazy. I sand the dowel to fill the tearout spot with sanding dust. The I apply thin CA. Let it dry for just a few seconds and then spread it gently with the sandpaper. Then before it has a chance to really dry I sand the area again. On deep ones it takes about 3 or 4 tries, shallow ones are usually filled the first time. It is easy to glue the sandpaper to your fingers but if you pull it off quickly it's not a problem. Below is a before and after. I start with course paper, about 150. Then as I sand through the grits I check for more tearout places and repair them. This doesn't work as well on light woods because the CA will leave a stain around the area unless you apply it with one of those micro applicators. Even then the sanding will spread it and if it has time to soak in to the surrounding wood it will stain it.
Re: I've been busy making dowels
phillip medghalchi
John, I think you did an excellent job on repairing the tear outs. BTW, what kind of gadget is it that you used?
Jorge
Good job John. A month ago I did 3 sets of 1/2 " drumsticks on th elathe and it took quite a while. After the fact I stumble into this:
http://www.ashemcrafts.com/products_trapping_plane.aspx
I tried one of these *LINK*
It worked fine on Maple. Didn't work worth a darn on the Cocobolo.
http://www.leevalley.com/US/wood/page.aspx?p=52401&cat=1,180,42288&ap=1
It's a homemade jig I learned about many years ago. It's simply a block of wood with 3 holes in it. One for the router bit to sit in. One for the square dowel to enter and one for the freshly routed round dowel to exit. As the square dowel passes the router bit it is cut to size.
