Dust Collector Filter
Bob Lalonde
Does anybody ever wash the filter bag on their dust collector? I was thinking that over time the upper bag could get clogged with dust reducing air flow. Just wondering.
Bob Lalonde
Re: Dust Collector Filter
robo hippy
With the older fabric bags, which would only filter down to 5 microns, they preferred for them to clog up a bit because then they would filter out some of the finer particles. With the newer ones, you should probably turn them inside out and shake them out like a rug. The pleated paper filters work much better, if for no other reason, they give you several times the venting area, so your collector can pull in way more air. Some of them even go down to 0.5 micron for filtering range.
robo hippy
ken ward
I washed the ones on my smaller Delta and after I ended up buying a new bag they worked great, you may ask why I HAD TO GET A NEW BAG ???? You DO NOT put the bag in the dryer,as it will melt the fibers.Yup it sure will.
