New steady rest idea - Any good? And a 2nd idea.
Craig Daymon
I was thinking about UHMW, since I just bought some to make center end caps from. (Cup centers, cones, etc.)
I started thinking of using it at the ends of the arms of a steady rest instead of skate wheels. Thought it might add an extra inch or more of diameter to the maximum piece usable with the rest. The UHMW is non-marring, slick, but not oily and long wearing. It doesn't absorb vibration as much as the urethane of the wheels, but then a steady rest is suppose to insure that the piece does not vibrate.
Also, for a non-jig, project idea, I was looking at David Springett's, "Woodturning Full-Circle", book and looking at the chapter on "Turning Square Holes" and, in particular, page 171, image 9. It would be possible to glue the 2 V-shaped sections together to create a square shaped, half circle. If before gluing them together, you epoxied in a very small strip of UHMW into the bottom half, you could then turn another square shaped piece to fit the curve and create a box with a drawer in a very interesting shape. It would require a very minor bit of flat work to make a door for the drawer.
The UHMW isn't essential, but it would help in smooth operation of the drawer. Might even help to use 3 strips, one on the bottom, one on the inside corner of the outer wall and one on the inside corner of the inner wall.
Might be a big project for my mini, but still doable.
Thoughts? Comments?
What is there to gain from using it over the wheels?
