So what's the difference between the powermatic 3520 and the jet 3520b other than the color, are they the same lathe but one for US and one for Europe ???
From the pictures I have seen the powermatic seems better finished, but is that the only difference
One difference that I know of is the diameter of the tool rest post. The 3520 is 1 1/8 and the 3520B is 1. I know because I made a custom tool rest for a man with a 3520 and it was too small.
there are several differences. The 3520 was made in McMinnville, TN. It had a different tool post which worked great. Shortly after it was made the company was bought out and the new lathe 3520A was made over seas. The first thing they changed was the tool post. It went to 1" which was more standard but they threw away the really positive locking system and went to the simpler but not as strong locking handle.
The 3520B made several good changes. The alignment pin for the quill feed was move to the back side of the tailstock instead of the bottom. It used to fall out all the time and now it's very solid. The added the ability to lower the short bed extension onto the legs to give you 30" of swing which you can't do on the 3520 or A series. They changed the design of the banjo so the tool post is offset which is very good for some things, not so good for others so I'm still iffy on this mod. I'm racking my brain to remember the rest, I think the 3520B has indexing built in where the 20 a A series don't. The B series has a blank area on the back of the threaded spindle to allow locking the chuck with a set screw. The A and 3520 don't have that. Can't remember anything else off the top of my head.
I like not having the cover. I stick CA glue or my tail center in there and have instant access. It does fill up with shaving however so maybe I do need one.
Thanks guys, is the jet any cheaper or dearer over the powermatic? If I lived in the US I can't see why one would buy the jet over the powermatic (I still say the powermatic looks better finished)
As far as I know they don't sell the Powermatic lathe under the Jet name here. The Jet lathes here are all 16" or under. They apparently rebrand the powermatic over there and call it a Jet.
