Coring Burls
Coring Burls
Coring Burls
Jorge
I have big burl caps coming, and never did core a burl, do they behave like side grain or end grain? Any thoughts will be appreciated. One is cherry the other black ash.
Thanks
Jorge
Re: Coring Burls
Re: Coring Burls
Greg Haugen
Jorge,
I've found they behave more like side grain, not bad at all. The key is to take your time, especially on a natural edge surface. Sharp tools are obvious - never have found anything that works well with dull tools :-)
Re: Coring Burls
Thank you Greag!
Jorge
much appreciated
Re: Coring Burls
Re: Coring Burls
robo hippy
The grain in burls is weird, kind of like it radiates out from a center point rather than being linear. Similar to coring end grain, I prefer to cut them all the way off rather than trying to break it out. Same reason, it can rip right through the bottom of your form. Cutter tip needs to be at center height to cut it all the way off. With the down ward pressure of cutting, and being extended out off the tool rest, this can be 1/2 inch or more below the center height that you get when you set up the tool with no cutting load on it. Try to remove the stub left from a standard bowl and you will see what I mean.
robo hippy
Re: Coring Burls
Got It!!
Jorge
Thank you Reed.
