Pour your next lathe? *LINK*
Leo Cuellar
I had never considered this option before. The wheels are spinning furiously!
http://blog.makezine.com/2012/04/12/the-concrete-lathe-project/
Leo Cuellar
i have seen it on large lathes
Steven Antonucci
The basic premise is to pour a large concrete block and use pillow block for your spindle. No idea why someone would go through the trouble for a small lathe, when you can buy them used for the same price...but in a big lathe, it certainly opens some doors.
If i recall correctly, Liam O'Neill has one. Google him to see it.
Re: Pour your next lathe?
Rob Wallace
The Vega 2600 Bowl lathe has about 100 pounds of concrete poured in the headstock:
http://www.southern-tool.com/store/vega_2400t_bowl_lathe.php
This concrete in the headstock seems to be for adding weight and vibration dampening, but NOT as a structural material.
Apparently concrete is good for dampening vibration - I would have serious concerns about generation of cracks and structural failure in poured concrete units unless sufficient reinforcing bar/wire was included in the structure, especially in high vibration situations which are common in woodturning. It would be interesting to hear from a structural/mechanical engineer to explain how durable concrete would be in this application. My gut feeling is that the junction between the headstock and lathe "bed" would probably be subject to extreme stresses and the possibility of catastrophic failure if this was just cast from a single pour of concrete without adequate internal reinforcement.
Rob
Jim Evans
Rob,
Concrete strength is measured in compressive PSI, high strength concrete is normally 6000 PSI compressive strength. The newer mixes have fiber reinforcing in the mix, so I wouldn't worry to much unless you are making a large lathe.
Denver Ulery *LINK*
clay foster
The late Denver Ulery from Redmond WA was doing this 30 years ago. He was also one of the first to put DC motors on lathes. You can see a picture of him at one of his lathes in this old American Woodturner article.
Denver Ulery
Design
Here is a link to a step by step "pictorial" of my concrete bowl lathe. It was begun by a guy named Mark Norman and inherited and completed, more or less, by me. Iy's still a work in progress as it needs a short bed and tailstock as well as a bigger motor and a VFD...
http://www.daviddecristoforo.com/lathe_gallery/index.html
Leo Cuellar
Nice pictures, and an interesting project. I think I would want to incorporate a removable gap or sliding rail section as I have a tendency toward off center work.
Did you track cost?
steven antonucci
I'd be interested in knowing about how much you've got into the lathe compared to large commercially available lathes? (if you don't mind me asking?)
It looks like a beast, and I would guess it weighs 1000#? Have you tried it out? Does it run well?
Inquiring minds want to know...
Steve
Re: Did you track cost?
David DeCristoforo
Well you are right about one thing… it weighs a lot! I don't think Mark had more than a few hundred bucks invested and most of the cost was in the bearings, pulleys and spindle. I got the spindle with the lathe but not the pulleys. My investment is very small because I had most of the needed parts on hand and a lot of stuff was "repurposed". It would have cost a couple of hundred to have the tool rest thingie made but I found a welder who was happy to trade (we have a restaurant) so I only spent twenty bucks on steel. All told, with little bits and pieces like nuts and bolts and washers (most of the "bolts" are lengths of all thread which is pretty cheap) and rattle can paint, I'm into it for less than a hundred bucks. Of course that does not include the motor which was sent to me for evaluation. It's a "Dynamotor", a variable speed single phase 220V motor that is more or less in the developmental phase. The problem with it is that it is a two pole motor and it has a bit of a problem starting up under load. A four pole version is planned but at this point, they are focusing on getting the cost (around $800) down. I am looking to replace it with a three phase motor and a VFD but at this point the dough is not available. I rigged up a crude belt tensioner so I can start the motor and then engage the spindle. That works but it's cumbersome. I also plan to build a short bed, tailstock and banjo but that is in the future also due to time and cost restraints. I looked into adapting a PM bed extension but the cost of that along with the tailstock and banjo is more than Mark and my investments combined. It has been an interesting project but it's no VB36!
Stephen Hogbin did it really big
I could not find it this morning but Stephen had one that was about 4 feet square at the bottom and maybe 16" at the top. Think a big pyramid with flat top. The tailstock was the same and was on rails sitting on the ground so it would roll. I might do one of those some day.
Re: Stephen Hogbin did it really big
Leo Cuellar
Thanks, John, I'll look him up & see if I can find pictures. Maybe mounted on I-beam with a trolley...?
Re: Did you track cost? *LINK*
Mike Brazeau
Years ago, I had bought a used custom made bowl lathe that was an excellent basic design with a new 2 HP motor and jackshaft setup, 20" swing. I thought about adding a bed expension so I could use it for hollowing or spindle work, a Oneway tailstock and a VFD and ended up selling it for $1000 and buying a Oneway 2436. Never regretted it since and my 2436 just turned 9 last month. I found your story similar in some ways to my experience. The fellow that bought it would like to sell if anyone is interested as he never really got it set up and running.
The Joy of Wood
Nice Bowl Lathe, Mike...
Brad Vietje
Hey Mike,
That's a pretty cool-looking bowl lathe. If you could send me the contact information for the current owner (off list), I could let folks know in my local turning clubs. I'm not in a position to buy it, but a friend might be interested. Adding a VFD shouldn't be too tough, and the fellow I'm thinking of would probably weld up his own tailstock if he felt he needed one (he has access to a local steel fabrication shop), so who knows? Driving to Ontario to fetch it might be the hardest part.
Safe spinning,
Brad Vietje
Newbury, VT
greenworksvt@gmail.com
Liam O'Neill made one...
GaryG in MD
for his large sculptural works. It's 12 HP and has a six-foot swing.
You can see a pic of him with it at page 6 of
http://www.ncwoodturners.com/Documents/v17n11-November-2007.pdf
Liam is an outstanding person and demonstrator and is interested in making some U.S. demo tours, so shoot him an email and see what you can work out -- been there, done that!
...GG
