Coring end grain: any problems to be anticipated?
Aage Rendalen
Every coring I've seen has been on side grain wood. What's it like doing end grain? I have some fine trunk pieces of ambrosia maple that I'd like to try it on.
Aage Rendalen
Re: Coring end grain: any problems to be anticipat
john Veerkamp
I've cored maple , elm, ash, mesquite and osage orange end grain with no problem. Use the same tips as hollowing end grain. Sharp tools and light cuts i.e. slower feed.
Doc Green
One thing I learned the hard way is that, with an end grain blank, you have to cut the core out completely.
With side grain, you can core down to a small section and then bump the core and it will break off. An endgrain core will not break off but will tend to pull a "plug" of wood from the bottom of the blank.
robo hippy
It will core a bit more slowly than side grain. You will most likely get chips rather than shavings. Probably biggest thing is that you need to cut the core all the way off. If you leave a 1 or even 1/2 inch tenon/stub and try to break or twist the core you, you can easily rip right through the bottom of the form you are coring. If you are using the McNaughton, you will most likely have to raise the tool rest when you get right down to that last little bit. With the flex in the blades and tool rest combined with the downward pressure of cutting, you will be 1/2 inch or more below center if you are 6 inches or more off the tool rest, even if you use standard 'extend tool all the way, lift on handle, and that is center height' method.
If you are brave/crazy/very experienced with the McNaughton, and have all the long handle on, you can lower the handle a bit till you feel that the tip is cutting at center height. This is 'professional driver on closed course DO NOT ATTEMPT type of skill though, and I do it, but don't really recommend it. The system is intended to be used with the handle raised up against the T bar or the newer square tube on the Mark 8.
robo hippy
