Jet Mini Bearing Replacement
Joe Pack
I didn't realize how rough and noisy the headstock in my Jet mini was until I attended a local club meeting and heard the Jet mini the club owned. The growling in mine just sort of crept up on me, I guess.
How difficult is it to change the bearings in the Jet mini headstock? Should I contact Jet for the OEM bearings, or head to a local bearing shop?
Re: Jet Mini Bearing Replacement
Re: Jet Mini Bearing Replacement *LINK*
Craig Daymon
It's not too hard. I did it several years back now. (Might be time I did it again.) I think there is a clip from the message board on the WoodCentral "Articles" page somewhere that talks about it and gives the bearings I used when I did it. (I put in a higher grade of bearings than the stock ones when I replaced them.)
I searched the archive and found the response thread for my post about this. The link is below.
A great source for information on the difference between the bearings (or almost any industrial supply) is McMaster-Carr ( http://www.mcmaster.com ). Look up bearings and you can get info on differences in the types. (Double sealed, tapered, etc.)
-Craig
Previous thread about JET bearings.
very easy
Dick Coers
It's a very simple procedure. I went to a local bearing shop, but wish I would have gotten a better class of bearing. The ones I got were really cheap, but not as quiet as I had hoped. Sorry, can't provide any part numbers or bearing info, but it's all over the web.
Joe Pack
Great information, Craig. Thanks.
Re: very easy
Joe Pack
Thanks Dick. I appreciate the reply.
Jeff Brockett
I replaced both bearings and the belt in my Jet mini lathe in under an hour.
