Trio of bowls
Trio of bowls
Trio of bowls
Joe Herrmann
I just finished the mesquite bowl on the right. I've been making the middle bowl for awhile and have been calling it a "square bowl". However, a friend recently told me it wasn't square, it was "rectangular"--OK, he's right. I got to thinking what an actual square bowl would be like so I made the mesquite one. I took some elements from the round one that will be coming up in the next issue of WTD so I could have sort of a trio of bowls.
Re: Trio of bowls
These are nice, Joe.
GaryG in MD
I like all three of them.
Good shapes and details.
Very crisp edges on the "not round" ones.
Good work. They make a nice trio. ...GG
Re: Trio of bowls
Mike Stafford
Re: Trio of bowls
Mike Stafford
I like all three but I am partial to the rectangular one I have. Is the reddish looking bowl turned from mesquite? Sort of a different color for mesquite. Did you dye it?
Re: Trio of bowls
Re: Trio of bowls
Joe Herrmann
Thanks Gary!!
No Mike, that's the color it was when I got it. I was told it was mesquite so I assume it is. All I put on it was Watco oil and deft.
Re: Trio of bowls
Mike Stafford
Re: Trio of bowls
Mike Stafford
Not to be a contrarian but that does not look like any mesquite I have ever seen. Someone with more mesquite experience may set me straight but it resembles some rosewood I once used in the lid of a treasure box I made.
See lousy picture below....
Re: Trio of bowls
Very Nice Joe- I like the square one best
Re: Trio of bowls
Re: Trio of bowls
Joe Herrmann
Thanks John!
Mike, the wood is actually a little more brown in real life. I'm taking the bowl to Utah in May so perhaps someone a bit more familiar with Mesquite can weigh in.
Re: Trio of bowls
I looked again at the larger image....
JamieDonaldson
...you posted on WOW Joe, and I don't believe this is mesquite either. I've turned a fair amount of mesquite and there is seldom any obvious ring structure, as well as a very distinctive but pleasant aroma. This appears to be some variety of rosewood, like santos, by the color and grain pattern.
Re: Trio of bowls
Rob Wallace
End Grain Image of Mesquite?
Rob Wallace
Any chance of seeing a close-up of the end grain of the mesquite?
If there are tyloses present in the larger vessels it probably is not mesquite.
It would also be good to see a ray and early wood/latewood cell patterns to discriminate between a few other possibilities.
It's hard to do ID's without close-up endgrain images..... ... the figure and color seem to raise questions for me of whether it is truly Prosopis or not....
Regardless, I like the piece, and probably should try to turn one of these kinds of bowls again - it has to be at least 4 or 5 years since I've done a "square" one....
Rob
Re: Trio of bowls
Very nice Joe
Mike Foster
like John, I like the rectangular (square) one best.
Re: Trio of bowls
Re: I looked again at the larger image....
Joe Herrmann
Jamie: 'll check again with the person who gave me the blank to see what he says.
Re: Trio of bowls
Re: Trio of bowls
Mike Rubes, Apex, NC
Hi Joe,
I like these a lot. I think they work very well as a set. I am fascinated by the long rectangle bowl. I like the bead work as well.
Thanks for the pics,
Mike
The times they are a changing in Apex, NC...
