Problem with emailer FIXED
Don Evans
Ok, in the below thread "Cann't see it" I indicated that if I click on an address on a message I could not get my emailer, Thunderbird, to start up. Instead the wizard to setup Outlook would appear. I don't use Outlook for anything.
I was convinced that the trouble was on my computer after talking with Ellis so I went look and found it.
Remember this is XP Pro:
Click on "START" lower left on screen
Click on "Set program and Defaults"
This brings up a window where you can choose "CUSTOM" (click down arrow out to the right of word "CUSTOM".
On the list that appears pick and choose the programs you want to have control. I just had to change the emailer and the problem disappeared.
Don
Re: Problem with emailer FIXED
H. Phillip Medghalchi
I still can't see the emial addresses of other members beside their names and also, Can't see where it would allow me to upload pictures form my computer to load up.
Don Evans
After you read this, click on "Return to forum" below this message.
Scroll to the top of the page and click on "Profiles", see if you are listed. If you are not then you have never made a profile.
I think you will go back to the forum and in the same area click on "My Profile" and that is where you will answer the questions.
If you make up a password, remember it, and you can use that in future to edit a message after you have closed it by bringing it back up (click on it) and edit using the password.
When you come to woodcentral, you will NOT have to log in.
But I could not find you in the profile list.
I'm no expert on any of this but I think above is what is causing you your problems.
Curious, when you reply to a message does it fill in your name etc automatically, if not that is another clue you don't have a profile created.
Don
