Refridgerator Kiln
Roy
I read a bunch of information regarding building a refrigerator kiln, but with limited space, I built one out of a large cooler. I drilled holes on the top and bottom, installed shelves, used a 40 watt bulb and small fan to move the air around efficiently. I loaded it up with 8 rough turned bowls and within a week the moisture went from 30+ to under 17%. But I lost 2 of the bowls due to cracking. I just received the thermometer/hydrometer I ordered and found the temperature to be at 87 degrees. I'm thinking this is way to hot to start the process.
Does anyone have advise on the what the temperatures ranges to use as the wood dries? The information I found only discussed starting with a 40 watt bulb and then using stronger wattage bulbs as the bowls dry but that was in a full sized refrigerator.
Thanks in advance any help you can provide.
