Food safe notices
Food safe notices
Food safe notices
Don in Central Illinois
Some time ago I think someone has a notice on how to care (wash/dry) salad bowls, that they gave to each purchaser. Did a search but haven't found anything yet. Starting to gear up for some summer shows and would like something to give to clients. As always, thanks in advance.
Re: Food safe notices
barry rockwell
barry rockwell
Don, I know Mike Mahoney has a printed card with those instructions and other info that goes woth his bowls but I can't quote what is says.
Thanks. I'll contact Mike.
Bill Jacksonville, NC
Early 1990’s walnut oil was cat’s meow for finishing turnings because it polymerized on the surface and mineral oil did not. So turners marched off to the grocery stores and bought $4 bottles of walnut salad oil and achieved mixed results. Might have better luck going to art supply store for their walnut oil that was cold pressed and heat-treated. Artist have been using walnut and other oils to mix their paints for eons. Could also buy flax seed oil same op cold pressed and heat treated at the art supply store too! Same problems with quality manufacturers do not always cold press or heat treat their oils but do add additives.
Walnut oil like linseed and Tung oil belong to class of oils (drying oils) that will polymerize on a surface eventually. Those oils can and do go rancid too!
No doubt, Mike Mahoney’s and Doctors Woodshop walnut oil products work well! Like all oil & oil/wax, finishes will need reapplication over time. Give them a bottle of product and tell them to reapply as needed.
I still think mineral oil the laxative a non-drying oil best food safe finish, and cheapest to reapply as needed finish out there. I can give customers a bottle for reapplying for less than $2. Never use industrial mineral oil or baby oil they are not foodsafe.
Emmett Manley, Lakeland, TN
More more Old Wives (or Woodturners) tales. All mineral oil is "food safe." The dose of mineral oil, a popular lubricant laxative, is at least a tablespoonful (15 milliliters) and often twice that -- and sometimes it has to be taken several days to produce the desired effect.
How long would it take a person to ingest 30 ml of mineral oil from bowl coatings?
In fact, drink a glass full of mineral oil and it will go right through your gastrointestinal tract with no harm -- just don't cough or bet that is gas you are about to pass.
I am not one to talk or mention any names but gee Emmett Manley what part of this sentence do you not understand?
“Never use industrial mineral oil or baby oil they are not food safe.”
No chit wives whale of a tail! Back when food safe finishes not even a concept. Bob Stockdale used mineral oil to finish artsy bowls sold to collectors. He uses mineral oil to finish ordinary bowls sold to people and department stores in San Francisco Bay area. He would dunk his bowls in a vat when stopped absorbing MO, put on a rack, excess oil dripped back into vat. After couple, days buffed off with a rag and off to market.
Why use mineral oil the laxative to finish, (decorate) bowls? Fit for human consumption easy to apply and reapply and because this non-dry oil will not go rancid!
Why never use baby oil, because scent & driers added to mineral oil base making it smell nice and less oily not good for human consumption.
Why never use industrial mineral oil, because of additives added make it unfit for human consumption.
Emmett, I too well remember ....
JamieDonaldson
...Grandma's cod liver oil, is that what it actually was? I know it smelled bad and tasted worse, and mineral oil would have been a big improvement! I found out after many years in the horse business that mineral oil was much cheaper to buy from my vet than at the grocery or pharmacy. :b
Re: Emmett, I too well remember ....
Jamie, yes cod liver oil is extracted from the liver of cod fish and it contains several fat soluble vitamins (A & D) plus other beneficial fatty acids. Cod liver oil was a good source of such nutrients in the days before commercial vitamin preparations. It sure did (does) taste terrible.
Mineral oil is a general term provided to simple hydrocarbons of mid-chain lengths. Beginning with methane gas (a single carbon) on through heavier gases (butane, propane, etc), on to liquids as the mineral oils, the straight chain hydrocarbons wind up with the long chain members which we term paraffins, and which are solid at room temperatures.
I'm wandering a bit but an important fact is that the mineral oils are essentially inert, not absorbed from the gastrointestinal tract, don't go rancid, etc. This makes them good lubricant laxatives and good for applications where a stable oil is needed.
And congratulations on your recent victory on the European PGA Tour.
I'm glad that golf Jamie won ......
JamieDonaldson
.......a tournament recently, so now I can proudly claim him as a kin! I believe some type of mineral oil is used as lubricant in racing engines, but haven't done research to see exactly what the formula differences might be? Do you know?
