dovetail jaws
dovetail jaws
dovetail jaws
Pietro Minca
Hello everybody, I have a Vicmarc 120 chuck with various dovetail jaws which I love and a small Oneway chuck with the patented profiled jaws. Now I would like to buy dovetail jaws for the Oneway which are called by Oneway smooth, and wonder if they have the same angle of the Vicmarc jaws. In other words, can one turn the same item on both the Vicmarc and Oneway chucks equipped with the respective dovetail jaws? Thanks.
Re: dovetail jaws
Re: dovetail jaws
I've never worried about having the exact angle of my jaws. I just cut a tenon or rebate with an eyeballed approximation and it's worked for the last 12 or 15 years that I've owned the vicmarc chucks.
Re: dovetail jaws
Re: dovetail jaws
Pietro Minca
Yes, i understand your point. I did the same until decided to sharpen at the right angle a skew. The point is that I have many jam chucks that I use on both the spindle, where I generally use the more powerful Vicmarc, and on the tailstock where I use the Oneway. Since I reuse them I like not to ruin the tenon and I make it at the right diameter thus I would like them to be interchangeable between the two chucks. This is why I would like to buy a set of dovetal jaws for the Oneway which, by the way, being small is perfect for many tasks at the tailstock.
Re: dovetail jaws
Re: dovetail jaws
Jeff Smith
I just looked at the Oneway smooth jaws for the talon - #3 and #2 sizes, and compared them to a set of Vicmark 4" jaws and a set of Vicmark step jaws. The angle appears to be slightly different. For that matter, the angle of the Oneway Talon #2 jaws looks slightly different from the #3 jaws. The #3 Talon jaw angle seems to match up with the #2 smooth jaws for the stronghold, though.
Without actually measuring, the angle of the Vicmark step jaws seems just a bit less than that of the 4" jaws, but that could be an illusion since the step jaws are so shallow by comparison. The 4" jaws I've got are pretty old - the were made by Vicmark to fit the Oneway chuck. I've never seen another set of them since I got these. The profile matches up with those on Vicmark's literature, though.
Re: dovetail jaws
Re: dovetail jaws
Pietro Minca
Thanks, this make me believe that the differences are irrelevant. Thank you again.
Re: dovetail jaws
Re: dovetail jaws
Peter Hyde
I just measured my VM100 and Talon No.3 jaws and they are identical. Also the Oneway jaws will fit the Vic but you have to use the Vic screws. Vic jaws will fit the Oneway if the Oneway screws are used but the holes in the jaws will need slight modification for size.
