Beall I-X Collets
Beall I-X Collets
Beall I-X Collets
Josh Bowman
Does anyone own the Beall I-X Collets?
What do you think of them?
What do you use them for?
How well do they hold?
Re: Beall I-X Collets
Hugh
Are you talking about the collet chuck? Where you change the collet to change the size?
Hugh
Re: Beall I-X Collets *LINK*
David Walser
No, Hugh, he's talking about a new set of expanding collets that Beall introduced a little while ago. The collets expand to grip the inside of a hole drilled in a turning blank. The set fits holes from 0.5" to 1.5" in diameter in 1/8" increments. Each collet has a half inch shank that can be gripped in a drill chuck or Beall's collet chuck.
Since they're from Beall, you know that they're well made. Looks like a cool idea. Should be perfect for pepper mills, kaleidoscopes, and similar items. I've not had a chance to use them.
Here's a link to Beall's website.
I-X Collets
Dennis in Southern Oregon
I bought a set a few weeks ago, but have not had occasion to use them yet. They look like a first-class piece of tooling; I don't expect you will be disappointed in them.
Dennis
Hugh
Thanks David for the info and the connection to the beall site. Nice looking tools.
I like Beall tools as they always seem to be well made. I have the other collet chuck made by Beall and like it a lot.
Hugh
matt overton
I do have them. They are very well made. They have come in handy twice when a jam chuck would have been the only other solution. they are great for small turnings. Like any woodturning tools, they are not a cheap solution, but I love having them.
Dave
Dave
I have a set and they are very well made. Came them in handy holding bird ornaments of various interior diameters as well as small boxes.
Josh Bowman
Well, we gave in to the vortex and just got our order in from Beall for the IX Collets.
Here's a mini review, since I couldn't find much on them. As said, they are well made and stored in a cherry block. The back part is a 1/2" spigot and not having a collet system, I used a drill chuck. I figured the worse case would be a pine 2x4 square. I thought this would put the most torque on the expanding collet and it being soft, would test the holding power of the collet. I also went at it with a 1/2" bowl gouge aggressively.
Here's the results. The first try, the MT2 spun out of the lathes spindle. Try #2 with a draw bar now securing the the MT2 drill chuck, the drill chuck spin off of the MT2 :( . Try #3 with the drill chuck now banged into the MT2, the chuck jaws spun on the expanding collets spigot :\ . Now with every thing tightened.......I easily cut the corners off of the 2x4 and was able to take aggressive cuts almost down to the expanding collets hole. The collet never offered to come out of the 2x4's hole, but was easy to release with the included allen wrench. As you can see the system will benefit from a 1/2" collet closing system, but if you tighten a chuck system properly, it will work as well. Now this IS NOT what these are for and there are better holding methods for such aggressive cuts, but as said this was a test.
Overall I'm glad to add these to my arsenal of tools. All that's required is to drill the correct size hole 1/2" deep and tighten the chuck lightly.
