I have an older Super Nova chuck with the star key (not the hex key), and I have noticed that it seems to "let go" of the thing that I am turning a lot more than it used when I wasn't as skilled. I know it's not me, and I am finding that it almost seems like the chuck is loosening it's grip while turning?
Does it seem to happen when using just one type of hold or both types of hold, in other words internal hold verse external hold?
I have seen one chuck that was 50 years old have the spirals start to break off from metal fatigue due to age. This was a 10" metal lathe chuck with 4 independent jaws (not self centering).
Its very common, and I often see chucks that feel tight, but they are simply bound up due to lack of lubrication. Blow the dust out and spray it with WD-40. No need to take it apart, or use any special lubricant. I do it to mine, and quite often in my demos/workshops.
Of course, I spray it liberally all over the lathe on a daily basis. The chuck only needs it now and then.
Steven, I think you worked the heck of that poor chuck. However, if you go on line to Teknatool's site there is a video about how to clean up and renew your Super nova. I agree with John once in awhile expecailly if you are turning lots of dry wood you need to blow at the highest setting on your compressor, and get the gunk out of the chuck.
I did have one Vicmark chuck, the smaller one, that stripped 2 pinion gears, and the spiral one on the inside. Craft Supplies had me send it back, and they sent me another one. No problems with it since then. I have had some problems with bowls not wanting to center very well when reversed, and in every situation, one of the jaws had loose screws. Not sure how they could loosen up, but they did.
