Jigs or fixtures you've made but not used?
Steven Antonucci
steven antonucci
Have you ever seen something that looked so useful that you couldn't wait to make one, and then found you almost never use it?
I have a donut chuck that fits that description. Most of the time, I am working small enough to fit the cole jaws... so it hangs on the wall behind the lathe.
What about you?
Steve
Re: Jigs or fixtures you've made but not used?
Mike Stafford
Mike Stafford
My donut chuck is under layers of dust on the top shelf. So is my router fluting jig and my sphere cutting jig. I am pretty sure I spent more time making the last two than I have using them. They work fine but I made them for specific jobs and I haven't had the need for them lately.
I guess I need to blow them off and use them once in a while before I forget how.
Rob Wallace
Rob Wallace
A table saw sled for cutting segments....
......Our chapter was doing a meeting on getting started with segmented turning, and I had previously purchased all of the hardware, toggle clamps, phenolic covered plywood, and other parts to make a quality, highly accurate table saw sled, which actually turned out great. I demonstrated the use of the sled at the meeting, and how it helps cut very accurate segments that needed no sanding for them to fit well. I probably made two segmented hollow forms with it following that meeting, and after about 2+ years I haven't touched the sled or picked up a bottle of glue, band clamps, or anything else to glue-up segmented rings. I guess this kind of woodturning does not generally fit my schedule very well, but at least I know I have a really good jig to cut accurate segments! Maybe if I ever clean off the table saw I could crank through a segment cutting session and make another seggie piece or two - they generally always sell well in the galleries where I sell my work.... ....maybe I'm just a "chunker" at heart?
Rob
Don in Central Illinois
My donut jig. More trouble thsn it's worth. Just collecting dust now.
None I built but one I bought
I got the 35mm chuck from Pennstateind. thinking it would be a great addition to my arsenal. To my knowledge I've never used it.
I do have some jigs that I built for my router and have no idea why I built them or what I used them for. I'm sure it was invaluable at the time.
Re: None I built but one I bought
bill Crommett
I built a veneer press to glue up segmented rings but it gave me too much glue slip, so I reverted back to gluing up the rings on the lathe where I had better control. There it sits, like so much of my other stuff, taking up space that could be used for something productive -- or something beautiful to look at.
Chip in Plano
I too have a segmented cutting sled. I made it based on Malcom Tibbett's book. Built it but never used it. Somewhere along the way, I figured out that cutting a beautiful piece of wood into little pieces then gluing back together again was another definition for insanity. Could be the my tablesaw is often covered over with other stuff.
My donut chuck was obsoleted by my vacuum chuck.
Bob Moffett
Bob Moffett
I made a chuck out of plastic pipe for hollowing ornament globes if I don't hollow them thin enough on the bottom. I haven't used it in several years.
barry rockwell
barry rockwell
I bought a very expensive "20" Modern Longworth Chuck" from Craft Supplies at the 2010 Utah Symposium because it looked cool and I wanted to turn some large platters. Finally tried it out last summer, 2012, and the first platter bottom was very scary. Tried it again to finish the bottom of a resin/wood platter I had worked on for a long time. Several of the buttons failed because they were too soft and the platter ended up in a lot of very small pieces. The good news is that when I called Craft Supplies to buy some new buttons so I could sell the chuck on eBay, and order a set of the Vicmarc Jumbo Jaws, they told me to just return it to them and they would give me a full refund, even after 2 years, because I was not happy with it. Then they sent me a "Return Shipping" label so I wouldn't have to pay for the shipping. Gotta love Craft Supplies.
