Question for newer Jet/Powermatic VS lathe owners
Kelly
I have an older Delta lathe that I have been working on and have decided to go with a 3ph motor/VFD set up to run it. In checking into this everything that I have found says to put the VFD in an enclosure, epically if it is mounted on the lathe, to protect it from dust, dirt, chips, etc. I noticed the last time I was in a Woodcraft that the Jet/Powermatic lathes with 3ph motors and VFDs have the VFD mounted on the back of the headstock with no extra protection.
My question is have you had any issues with the VFD mounted where it is with nothing extra to keep the dust, dirt, chips etc, out? I am sure that WMH would not put it there if there were going to be problems with it costing them money in warranty work from damage but I would rather not have to replace it before I needed to if I can help it by putting it in an enclosure.
