Other Bandsaw problem
H. Phillip Medghalchi
In addition to what John Lucas has experienced with his Band Saw, I have this problem that my band saw creates such big mess of fine saw dust when sawing any wood, whether it's timber or log to especially dry wood. I have a Jet 14" Band saw with riser which I have added, however, the dust port is the the one that comes out the side directly under the table to the right of it,(this is not like the newer version which has a 4" port at the bottom panel on the back side of the body) which is made of the black plastic and it seems to be about 2+", and a regular 2 1/4" hose doesn't quiet fit it right unless you fit it with some kind of a rubber around it, then force it to fit. This appears to be like when you are working on the lathe, instead, the wood is very dry and make a giant dust all over the place.
Has any one have this problem with their band saw and how did you remedy it? Any help with greatly be appreciated.
Re: Other Bandsaw problem
robo hippy
I haven't seen a dust collection port/set up on a bandsaw that even came close to working the way it should. Some are set up right by the lower blade guides. At least half of the dust goes down inside. My big saw has the port down low, and behind the wheel. Again, not where it needs to be. Some day, I will cut one in the door, down even with the bottom of the lower wheel. This is where I always seem to get the pile ups.
robo hippy
Robo, I try and post a pic. tomorrow for you guys to see the darn thing just make the dust fly to the left side as well as right and then under the lower wheel on the bottom of the door and God knows where else and I wonder the guys with the 18" or fancier Rykon or Powermatic, or any of those high dollar band saws have the same problem?
Harry Robinette
Harry Robinette
I have the 18" Rikon and I do get that fine dust all over the table. I have put another dust pick-up just under the table under the table insert and it has helped allot.
But I believe every band saw has dust control problems JMHO.
Josh Bowman
Mines as good as I've seen and it's just ok. It's a Laguna 14 SUV and like Reed said it has a direct dust port under the blade and the blade passes through a box with a piece of MDF at the bottom so it does pretty good. There is also a port at the bottom of the saw under the lower wheel, not certain it does and good and it might just reduce the suction at the upper box.
I have the same problem. I've been working on it. I'll take some photos tomorrow. I shot some photos before. My dust collection is better but still lacks seriously.
Don Evans
My MiniMax MM16 works very well, it is very similar to the Laguna I think, the box they made below the table insert is also adjustable. A lot of it's capability has to do with what dust collector you have of course. Im using an Onieda cyclone.
Prior to this bandsaw I had a 16" Grizzley that I made a dust collector setup for it. It was an idea that someone else came up with and put it in the public domain. It consisted of a 4" pvc pipe that you had to modify the right side of the saw so the pipe went up inside the bottom wheel well. The top of the pipe was cut at the necessary angle to make it fit snug against the bottom of the table, here is the important part of it's success, the side of it was also cut out so the blade entered the pipe at the top middle of the pipe and came out of the pipe lower down out of the side of it. This put all the air movement stripping the dust out of the saw gullets. You've got to leave enough room at side cut out and top of pipe for air flow of course, balancing that was a little critical for maximum efficiency but very do able. It worked perfect.
The pipe was held with a wooden bracket and held to the saw with magnets for easy removal as it had to come off for blade changes.
It worked the best of any I've ever seen. Wish I could remember where I got the idea but it was early 2000.
Don Orr
I have the exact same saw-Jet 14" w/riser block, several years old. The original dust collection is a total joke and absolutely worthless. I cut a 4" hole in the lower door and attached a 4" line from my dust collector and it's better-not perfect though. There is more I could do to enclose the blade and seal up other gaps but this works pretty well for now. I still vac it out after each use but there is not much there usually. I did a few cuts recently without the DC on and was reminded how much the DC really does get. Big mess without the DC, small mess with it.
robo hippy
My little bandsaw is an older PM industrial 6 inch saw, which had a 2 inch angled pipe near the lower blade guides. My big one is a Laguna 16HD. It had a 4 inch port on the back side of the saw, which was 'around the corner' in the frame. I have an Oneida 3 hp dust collector. When I get around to it, I will install a floor type vent in the door of each. Opening would be rectangular about 3 by 10 or 12, and be right at the bottom of the door which is where all the dust and shavings seem to collect. I think most dust collection for bandsaws was designed around 1/4 inch or smaller blades for cutting lots of curves in dry wood.
robo hippy
waltben
I used to have an MM20 and duct taped all the various gaps and holes between the table and lower sheet metal. Since I never tilted the table but twice in six+ years, this worked fairly well. It still left some dust, but not much. Most of the problem was what piled up in the bottom of the machine.
After downsizing, I've now got a Grizzley 14" w/riser block and it's pickup isn't. Someday I'm going to fix the port (there's a cast 'grate' over it) and get around to blocking the gap between the table and lower sheet metal. This saw has a much larger gap though, so I'm not certain how to go about it. It's orders of magnitude messier than the MM20 was, and I've got to do something about it.
Don, would you be kind to take a picture for me to clarify this concept. It sound easy, however I have difficulty to picture it. I'd very much appreciate it.
Don Evans
Sorry but that saw is history to me. I gave it away when I got the MiniMax and the person who got it does use dust collection so he took the pipe off and dismantled the assembly.
This was about 3 years ago also.
Don
I have a similar Delta saw with riser. My solution was to trash the stupid joke of a port that came with it and install my own four inch port. I first attempt was to put a hole through the door for the port. That worked better, but was a hassle when it came time to change the blade. (It constantly pushed the door shut.) What I have now is a port on the right side under the table made out of an "End Boot" for four inch Duct.I use an eye bolt to hang it from the old support and It comes off easily when I change the blade. Works better than either of the others. I can tilt the table also. Put the blast gate near the switch. I may have pictures if you are interested.
At one time Delta made a similar port for the machine, but did not advertise it much. Might check with Ittura to see what he has.
Barry, I'd be interested to see a pic. if it's not too much trouble to get them.
I am thinking that there must be some one out there who owns a band saw that doesn't make all that mess can can share the pic. with us so we can fabricate something for our low down the line band saws. Or, is there any band saw which A high dollar one which will not endure such a mess? Or, is that too far fetched?
