?? about CBN Wheels
?? about CBN Wheels
?? about CBN Wheels
Joe Meirhaeghe
I've read some where on one of these forums that using a CBN wheel on carbon & mild steel will ruin the wheel. That you should have a second grinder set up if you want to grind mild steel. Now is this a fact or just a he said she said story about them.
Now my question here is does anybody know what the actual manufactures say about this.
What do the manufactures say they can be used to grind ??
Re: ?? about CBN Wheels
Chuck Engstrom
Hi Joe -- I have seen two suppliers (D-way and Craft Supplies) give strong warnings not to bring anything except high speed steel to a CBN wheel or you will cause "irreparable damage."
Regrettably, neither of them provides any explanation of what the damage would be or what it is about softer steels that is so destructive -- it's just kind of "Because I said so and I'm the grown-up." It seems pretty sensible to figure that anything softer than HSS might gum up the grit, which can't be refreshed with a diamond dresser or such the same way an aggregate wheel can. Brass or aluminum would be even more of a problem, I suppose.
But this is just guesstimation on my part. A more exact and complete explanation would be welcome.
Best to all -- Chuck
Still new with this wheel and still looking for information but one source said that if you grind a carbon steel tool it doesn't ruin it. Not necessarily anyway. YOu can grind a HSS scraper and it can clean out the carbon steel. Now I've only read that from one source.
Since most of our grinders have a second wheel and most of us have very few carbon steel tools. Well actually I have several since I make many of my hollowing tools out of drill rod and make special cutters out of old screwdrivers and some files. These can easily be sharpened on my white wheel and save the CBN for the HSS and particle metal tools.
Scott Crumpton
At the last IWF I talked with a rep from a company that makes industrial CBN abrasives. I specifically asked him about this. His response was that the non-HSS sticks to the surface of the CBN wheel making it less effective and causing heat. It does not ruin the wheel unless done excessively. The wheel can be cleaned using a special cleaning stick just like you can clean a sanding belt with a rubber stick. The stick for cleaning CBN is actually made from, now get this, aluminum oxide. He had a couple different cleaning sticks, I assume for different applications, that he showed me.
I have D-way wheels and will occasionally touch up the edge on a carbon steel tool. Probably less than 2% of my total use and have seen no issues.
---Scott.
robo hippy
I talked to Dave at D Way tools. His comments were that the softer carbon steels can clog up the wheels. To clean them, take a heavy scraper to the wheel and sharpen the scraper as normal. This will clean it up.
The first CBN wheels I had, maybe 8 years ago were a matrix type, similar to the Woodcraft diamond wheel, with 3/16 inch of grinding matrix bonded to an aluminum hub. They were made locally. They gave me some very hard aluminum oxide to clean the wheels. They actually used this to true the wheel. I didn't find it to be effective at cleaning the wheels. I later saw how Cindy Drozda would clean her Woodcraft wheel (some where on You Tube) by having a brush with an oil on it. This would keep the steel from clogging up the wheel. I did try an old diamond dresser tool to the wheels once, and they wheels ate the dresser.
I do not think I would take aluminum oxide to one of the electroplated wheels. I would think it would remove the abrasive. I will ask Dave about that one.
Bench planes and chisels are fine on the electroplated CBN wheels. A lawn mower blade is a bit on the soft side. I haven't tried brass or aluminum.
robo hippy
Dietmar
I`m familiar with cbn wheels since more than 30 years and my company was the first one to introduce them to the woodworking community, almost 5 years ago in Europe.
Don't use CBN on mild steel or aluminum, zinc, etc. use it on
hardened steel, carbon or HSS
occasional use on tungsten carbide is okay.
If you use it on mild steel or those other metals, it will clog and there is no straight forward way to clean it. If it has happened, probably the best chance to get it back is keep on grinding with HSS tool, very gently. . There is a stick which has been used with a little success, I'm out of town and don't have the info with me.
Am I reading you correct in saying that a hardened piece of drill rod, Allen wrench, screwdriver or file would be OK to sharpen. These tools have been rehardened after shaping. Also wondering about the old Craftsman High Carbon Steel tools.
It sounds like what you don't want applied to the wheels is soft steel and non ferrous metals.
Dietmar
that is quite true, there are a few exceptions from this rule but what you use as a general one is: hardened carbon steel or HSS are just fine to grind with CBN. You will get a few sparks with carbon steel, but not as many as with alox.
That applies to all types of cbn wheels, but the electroplated ones will cut much easier - freer as we say here - than epoxy or metal bonded ones
thanks for the info
