Bandsaw problem
Bandsaw problem
Bandsaw problem
I've had this happen before and don't know exactly what it is. The blade seems to be either grabbing or flexing. This seems to be pulling down on the top wheel which makes the blade flex, then it makes a popping noise and slams against the wood leaving a sort of chatter texture to the cut and feels like it's getting a catch in the wood. It's a very jagged cut.
It acts like there isn't enough tension on the blade. I have a new ittura spring and tension it to the 1/2" setting. This is on a 14" Delta with riser block.
Re: Bandsaw problem
Keith Tompkins
Re: Bandsaw problem
Keith Tompkins
Hey John, what blade are you using? Is the guage for tensioning accurate?
Re: Bandsaw problem
Re: Bandsaw problem
robo hippy
Most bandsaw tension guides are worthless. I have experienced that type of 'kickback' on the bandsaw. It seemed to be more related to guides (thrust bearing/one pushing on the back of the blade) not being lined up properly, and/or a dull blade, or several bent teeth. Another contributor can be a piece of wood that is not flat/square/straight.
robo hippy
Re: Bandsaw problem
Re: Bandsaw problem
Ken DeMarco
John, I just had this problem with my bandsaw. a 17" Grizzly 0513. went thru adjusting everything, changed blades twice, but nothing helped. Turned out the tire on the bottom wheel was loose. Replaced tires and the bandsaw works like new. Found out the problem by running with doors open and I could see the tire pulling away from the wheel.
Ken DeMarco
Re: Bandsaw problem
Re: Bandsaw problem
Keith Newton
If you are running a coarse blade with positive hook, the chisel action can pull itself into the wood faster than the feed rate, jambing the blade.
I think you need a little more back tilt on the top wheel, to keep the blade on track.
Also, make sure the tires are clean. I'm sure you already know that crud building up can affect tracking.
Re: Bandsaw problem
Re: Bandsaw problem
Don McLeod
John I don't have a solution to your problem but you might try YouTube and view a video from Carter Products called "Band Saw Clinic with Alex Snodgrass" it will take a half hour of your time and it just may provide you with a solution . It certainly covers a lot of ground.
Re: Bandsaw problem
Re: Bandsaw problem
Don Evans
John, I'm not sure what causes this either but I've run into it once. Let me say that I have a very robust, heavy saw, a MiniMax MM16. The wheels weight is about 50 pounds each. This happened with me when I decided to resaw a piece of cocobolo 3/4" x 3".
I tried resawing at two different thicknesses trying to figure out what made that noise and it did it both times. Switch to another piece of wood and no more trouble, didn't do anything to the machine. That was several months ago and hasn't happened since.
What I believe caused the trouble was I was using a 1/2" blade that was 6 tpi, that put too many teeth in the 3" piece of wood and it was also slightly bowed.
I'm guessing the part of the blade that was inside the wood slowed way down fast but that heavy wheel didn't and kept trying to feed blade into the wood or bearing guides.
With it's 5hp motor it doesn't stop for anything and the flat (not crowned) tires don't slip.
Point is I think there are multiple possibilities to what can cause this, wood, slippage, blade and on and on.
Don
Re: Bandsaw problem
Re: Bandsaw problem
Galen Vetterick
When I had the poping and grabing I found my motor belt tension was too loose. Like it had been years since I adjusted it. Once done the problem went away. You might check the belt.
Re: Bandsaw problem
Re: Bandsaw problem
Wow A bunch of possibilities. I'll try some of them later today or tomorrow. One problem which I don't think was related is the insert had broken. I spent the last hour or so building one out of aluminum. After dinner I'll put the new insert in and give the saw another try.
I was cutting some dry Osage about 4" thick with a 1/2" 3 tPI blade. I will clean the wheels, that's quick and then maybe try running it with the doors open to see if I can trace the problem. I get it every once in a while and not sure what it is. The guide bearings are all adjusted properly, I always check those when I put a new blade on. This blade is fairly new.
Re: Bandsaw problem
Keith Tompkins
Re: Bandsaw problem
Keith Tompkins
John, your problem, especially with the broken insert is the wood is bouncing..I'll be you are using a 3 tpi blade with a hook tooth. Very agressive, especiall when crosscutting. A skip tooth blade has 0 rake, while the blade you're using may have 10 degree rake. Switching on very hard woods will help if all else is fine.
Re: Bandsaw problem
Re: Bandsaw problem
Keith I think it's a combination of the blade and hardness of the wood. I added the new insert. I cleaned the wheels, checked the motor belt tension. It didn't look like the blade was slipping on the wheels but it's kind of hard to cut, watch the blade and not cut fingers.
I'm going to change blades tomorrow and see if that does it. I probably do need new tires. I was pretty sure I bought a set at some time but could not find them tonight.
Re: Bandsaw problem
Re: Bandsaw problem
H. Phillip Medghalchi
John, I had that happened to me and this is what I figured out. If at any time in the past you tried to cut a log or any thing which was not flat sitting on the table and accidentally you had the log or round moving to one side and in the process it got a catch and moved the blade to a kink, but didn't break it. However, a kink or bend happened on your band. You go on and keep sawing, but happened here is that your blade is no longer straight or if you lay it down on a flat surface all of your blade will sit on the same plane. so, when this happens on the way to coming to contact with the wood it is not on the same line as rest of the blade and therefore it hits or rubs against your guides or bearing. the evidence of this is that you already tried to make another insert for the table which was i am thinking way too large and it was not zero clearance around the blade. I changed my blade and that stopped. I also, agree with Keith that different density wood will grab differently too. I don't have guide bearings on the side, I have the Jet 14" with the riser that I added on. I have to change my insert too due to the above problem. I hope this will help.
Re: Bandsaw problem
Re: Bandsaw problem
I changed the insert because it was on of the nylon ones and over the years has simply been worn out. Replacing it with the new one didn't do a thing. I did get a catch cutting big Oak log the other day. I suspected the blade but if I touch it gently with the tip of a screwdriver there isn't any bounce or movement at all. I also checked it visually. Seems to be fine. However I will replace it tomorrow with a finer tooth blade just to see.
