Finisishing a Turning
Allen
I have recently turned my first pepper mill. While not an experienced turner, I'm very pleased with the outcome. Previously I've only made a few pens, but I've been expanding my horizons.
Because pepper mills encounter food, I've got a question on finishing. The mill is made out of Sycamore which as I understand is not one of the oily woods. How do I go about putting a protective finish on it while still being food safe. Do I need to finish the outside only, or do I also need to do something to protect the inside area where the peppercorns go?
Re: Finisishing a Turning
john Veerkamp
you can finish the outside only. "Food Safe" doesn't matter here. Actually any cured finish available today is food safe. Use Whatever you like the looks of. Since messy hands will be touching it, I'd finish with a poly.
Pete in Holland, MI
Yup....this is discussed often times on this site.
As mentioned before, most any finish these days, once cured (can't smell the solvent anymore) is food safe. Lead is not used anymore in finishes.
Think about it: if you drop a meatball on a wood table, are there concerns about stabbing it with a fork and eating it?
Good point on the messy hands. I second the choice on Polyurethane.
Pete
Shellac on the inside
Craig Daymon
Shellac is food safe to the point of being edible. It's used as a coating on many candies, such as M&Ms. Eventually, because of the abrasive nature of the pepper kernels, the inside finish will be worn away, but shellac on the inside will dry quickly, be food safe, and minimize the sawdust content of the pepper you grind.
When they talk about food safe, I believe that means it is safe to come into contact with food once cured. That being said, many finishes contain ingredients that you don't really want to grind up and mix with your pepper. Also, almost any finish used on the inside will take longer to completely cure. (In the case of shellac, you only need for the alcohol to vapor off, which is pretty quick.)
If you were to use an oil finish on the inside, it might take an exceptionally long time to dry.
This is what I believe to be true.
My suggestion is for shellac on the inside.
-Craig
Pretty much anything goes for the outside.
Re: Shellac on the inside
Allen
I was told that if I was using an oily exotic wood that I should put shellac on the inside to prevent the oils from flavoring the peppercorns. Sounds like it may be a good idea for any wood.
There is no real reason to apply .........
JamieDonaldson
...any finish to the inside of any grinders, and the new water based Woodturners Finish is another good durable candidate for exterior finish.
Steven Antonucci
I have made a few and insides are unfinish
Steven Antonucci
and straight off the drill bit. No sanding. Nothing...
S
Bernie Weishapl
I put two coats of mixed shellac inside of mine. I started doing it with cedar and I just continue to do it with all my mills. I either use lacquer on the outside or Drs. Workshop High Build Friction polish (shellac and walnut oil).
