More on LV 1"x42" belt sharpeners
Jack Guzman from Maine
I just put one of those together for use with my turning tools. I have a slowspeed grinder with an 8" blue norton wheel that I use for shaping. I want to use the belt for final honing. I know nothing at all about grits and type of abrasive.All this blue zirconia oxide aluminum gold stuff is greek to me. My sander came with a 120 grit belt and I ordered a 15 micron gray thing thinking that it would be all I need but reading the posts here I'm starting to get very confused.
I'm looking for guidance. What type/grit belt will work with my tool for final honing on my HSS turning tools. Does my plan make sense? --Grind with the blue stone and hone with the belt .---Jack
Re: More on LV 1"x42" belt sharpeners
I'm still researching this and just ordered some belts today. They won't be in until middle next week or a day or so later. I have used standard belts on another sander for shaping and polishing metal. 600 grit will make it almost a mirror finish. I'll know more when I get the belts that I ordered and play with them.
Don Stephan
A lot of turners only use an 80 grit wheel on a grinder with no honing. Not sure how much difference you will see in the surface of the wood if a turning tool is honed. I've used the LV sander on carving tools just a bit, and my experience is that the sanding belts dull pretty quickly. Once dull, the belt cuts more slowly and heats the tool more quickly. Honing certainly makes a difference with carving chisels.
Wally Dickerman
Don, I use blue zircon belts for part of my sharpening. Zircon will last several times a long as AO belts at near the same price.
I just ordered 3 different types of belts from Klingspor. The blue zirconia belts are designed to cut metal and wear more slowly. I can't find them finer than 120 grit. I order some 600 and 800 belts that are of a material I haven't heard of. I'll let you know how they work.
One thing I have learned and that is there are alot of differences of opinion on sharpening turning tools.I found that I have better results with my tools honed. What I don't understand is all the different choices in sharpening belts.I tried to order some and realized I had no clue what to buy.I don't understand any of it. Aluminum oxide and zirconia are just fancy words to me.If both are the same grit what's the difference and why are some good for sanding wood and some for sharpening metal .I just want to order a couple belts . I don't want to have to study metallurgy to do it.
I'm hoping someone here can help me understand better so I know what to get.---Jack
Re: More on LV 1"x42" belt sharpeners *LINK*
Bob Entwisle in NJ
Jack,
There was a thread on the Hand Tool board a week or two ago about belt grinders. There's some good info there on belts and such.
Might be worth a look.
Here's a link to the thread.
Bob in NJ
Belt grinders
I have the zirconia 120. I'll try that for now and wait to hear your results.---Jack
Thanks Bob I had forgotten that thread. I will read it through. ---Jack
